sudo make install
make[1]: Entering directory '/home/nio/Documents/Tools/pcan/peak-linux-driver-8.10.0/driver'
Info: /lib/modules/5.3.0-46-generic/misc exists.
make[1]: Leaving directory '/home/nio/Documents/Tools/pcan/peak-linux-driver-8.10.0/driver'
make[1]: Entering directory '/home/nio/Documents/Tools/pcan/peak-linux-driver-8.10.0/lib'
mkdir -p /usr/lib
cp -d lib/* /usr/lib
if [ -d lib32 ]; then \
mkdir -p /usr/lib32; \
cp -d lib32/* /usr/lib32; \
fi
mkdir -p /usr/include
/sbin/ldconfig
make[1]: Leaving directory '/home/nio/Documents/Tools/pcan/peak-linux-driver-8.10.0/lib'
make[1]: Entering directory '/home/nio/Documents/Tools/pcan/peak-linux-driver-8.10.0/test'
make[1]: Leaving directory '/home/nio/Documents/Tools/pcan/peak-linux-driver-8.10.0/test'
make[1]: Entering directory '/home/nio/Documents/Tools/pcan/peak-linux-driver-8.10.0/libpcanbasic'
make[2]: Entering directory '/home/nio/Documents/Tools/pcan/peak-linux-driver-8.10.0/libpcanbasic/pcanbasic'
cp libpcanbasic.so.4.3.4 /usr/lib/libpcanbasic.so.4.3.4
ln -sf /usr/lib/libpcanbasic.so.4.3.4 /usr/lib/libpcanbasic.so.4
ln -sf /usr/lib/libpcanbasic.so.4.3.4 /usr/lib/libpcanbasic.so.0
ln -sf /usr/lib/libpcanbasic.so.4 /usr/lib/libpcanbasic.so
cp PCANBasic.h /usr/include/PCANBasic.h
chmod 644 /usr/include/PCANBasic.h
/sbin/ldconfig
make[2]: Leaving directory '/home/nio/Documents/Tools/pcan/peak-linux-driver-8.10.0/libpcanbasic/pcanbasic'
make[2]: Entering directory '/home/nio/Documents/Tools/pcan/peak-linux-driver-8.10.0/libpcanbasic/pcaninfo'
cp pcaninfo.1.0.3 /usr/local/bin/pcaninfo
chmod 755 /usr/local/bin/pcaninfo
make[2]: Leaving directory '/home/nio/Documents/Tools/pcan/peak-linux-driver-8.10.0/libpcanbasic/pcaninfo'
make[2]: Entering directory '/home/nio/Documents/Tools/pcan/peak-linux-driver-8.10.0/libpcanbasic/examples'
make[3]: Entering directory '/home/nio/Documents/Tools/pcan/peak-linux-driver-8.10.0/libpcanbasic/examples/c++'
#cp pcanwrite pcanread pcaneventread pcaneventwrite /usr/local/bin
make[3]: Leaving directory '/home/nio/Documents/Tools/pcan/peak-linux-driver-8.10.0/libpcanbasic/examples/c++'
make[3]: Entering directory '/home/nio/Documents/Tools/pcan/peak-linux-driver-8.10.0/libpcanbasic/examples/python'
make[3]: Nothing to be done for 'install'.
make[3]: Leaving directory '/home/nio/Documents/Tools/pcan/peak-linux-driver-8.10.0/libpcanbasic/examples/python'
make[2]: Leaving directory '/home/nio/Documents/Tools/pcan/peak-linux-driver-8.10.0/libpcanbasic/examples'
make[1]: Leaving directory '/home/nio/Documents/Tools/pcan/peak-linux-driver-8.10.0/libpcanbasic'
sudo modprobe pcan
modprobe: ERROR: ../libkmod/libkmod-module.c:979 command_do() Error running install command for pcan
grep PEAK_ /boot/config-`uname -r`
CONFIG_CAN_PEAK_PCIEFD=m
CONFIG_CAN_PEAK_PCMCIA=m
CONFIG_CAN_PEAK_PCI=m
CONFIG_CAN_PEAK_PCIEC=y
CONFIG_CAN_PEAK_USB=m
lsmod | grep ^peak
peak_usb 45056 0
