Diag FD symbol file - no decode data in scope
Mobile Diagnostic Device for CAN and CAN FD Buses
blbus
Post by blbus » Sun 10. May 2020, 23:21
On PCAN-Diag FD, Should there be decode information in the scope view when a symbol file has been associated.
When no symbol file is associated in project, the Scope RX view does show the received data decoded and information about the received message. If I add a symbol file to the project, it transfers fine and I see the symbol representations in the "View CAN as Symbols" option - the scope however, has no decode information. How do I see decode info when a symbol file is in the project?
U.Wilhelm
Re: Diag FD symbol file - no decode data in scope
Post by U.Wilhelm » Mon 11. May 2020, 07:37
The Layer 1 mode (Scope) decode the Bit Stream in a readable CAN Layer 2 Format only. (ID, DLC, Data Bytes, and all other needed Bits)
A decoding in Layer 7 (Signal based) is in this mode not possible. Symbol File decoding is only possible in the Layer 2 (CAN) when send/receive real CAN Frames.
blbus
Post by blbus » Mon 11. May 2020, 15:33
Fair enough. After a day playing with and learning the tool that was my only question. Nice product.
