PCAN-Router FD Conversion Latency
Post by M.Heidemann » Mon 25. May 2020, 11:08
Many of our customers request the conversion times from CAN FD to CAN 2.0 using the PCAN-Router FD.
We have created a trace as reference:
This trace was recorded at 80 Mhz, 500 Kbit/s nominal-bitrate and 4 Mbit/s data-bitrate.
The test was run link this:
A PCAN-USB FD was used to send FD-frames (via PCAN-View), using a T-Adaptor the message was sent to both channel 2 of a PCAN-USB Pro FD and to CAN1 of the PCAN-Router FD.
CAN 2 of the PCAN-Router FD was connected with Channel 1 of the PCAN-USB Pro FD.
We used the firmware example from this forum-post:
viewtopic.php?f=199&t=5627
The first FD message (0x100h)(DLC = 8) is converted from CAN FD to CAN 2.0 in about ~227 µs
Second FD message (0x200h) (DLC= 64) will be split into 8 CAN 2.0 messages (0x200h - 0x207h) is converted and completely transmitted in about ~2 ms (with about ~233 µs to ~250µs between each CAN 2.0 messages), the first converted message of the eight frames arrives after 233 µs.
CAN FD message (0x100h)(DLC=8) was sent 4 times afterwards with an average of ~228 µs converion times (CAN FD - CAN2.0)
You can download the trace file here:
2020-05-25_10-29-48_650.trc
(2.38 KiB) Downloaded 6708 times
