Fatal error: PCAN-ISO-TP_2016.dll couldn't be certified [PCAN-PassThru API]
MarcK
Post by MarcK » Thu 28. May 2020, 10:27
I am trying to use a PEAK PCI CAN Adapter through the PassThru API (v. 2.0.0).
Loading the PCANPT32.dll and methods succeeds, but calling PassThruOpen leads to a "Fatal Application Exit":
The reason for that is that the PCAN-ISO-TP_2016.dll coud not be found.
2514:0ac8 @ 03430515 - LdrpProcessWork - ERROR: Unable to load DLL: "PCAN-ISO-TP_2016.dll", Parent Module: "(null)", Status: 0xc0000135
However, the user manual for the PT API states:
Note: The required APIs PCAN-Basic and PCAN-ISO-TP are installed both with the PCAN-PassThru setup.
Nevertheless, I couldn't find the PCAN-ISO-TP_2016.dll anywhere on my machine. It is also not present in the PCAN-ISO-TP API v.3.0.0 package.
Question:
Where can I find the PCAN-ISO-TP_2016.dll? Do I have to manually install it, or is it just currently missing in the download package?
Thank you in advance
Marc
Re: Fatal error: PCAN-ISO-TP_2016.dll couldn't be certified [PCAN-PassThru API]
Post by K.Wagner » Thu 28. May 2020, 10:36
it looks like an old reference has been kept in the API. We will check this asap. If you send us an email to support[at]peak-system.com making reference to this post, we will be able to provide you with a RC version for testing, as soon as we get a fix for this.
Thanks for bringing this to our attention.
MarcK
Post by MarcK » Thu 28. May 2020, 12:42
Thanks for the quick reply!
I'll just be using the previous version of the API until the fix is released.
All the best,
Marc
Post by K.Wagner » Thu 28. May 2020, 15:30
we have fixed the issue and released a new version 2.0.1.
