Hello Team,
I would like to count an error while receiving CAN messages thru PCAN-View.
while receiving, if CAN error occurs, I can see "ESI" on type column and disappear by the following message.
however I will not able to count or monitor the window all the time,
hence I would like to know the statistic of Rx messages (e.g. 10 error out of 10000 msg, etc)
does PCAN-view provide similar feature?
please advise, thanks.
how to count error on PCAN-View 4.2.5.569
Re: how to count error on PCAN-View 4.2.5.569
Simply use the Trace TAB and set in the Trcae setting the Filter for your need (error frames, error counter changes ...) simply deselect what you do not need. then start the tracer..
