Default on PCAN-USB
Waynes
Default on PCAN-USB
Post by Waynes » Sat 6. Jun 2020, 02:58
I always use my software with the configuration below :
drive_500 (1)
ucap_500 (2)
and when I tried today impossible.
there is the PCANLight_USB_16 which appeared without any creation from me.
How to deactivate or delete the PCANLight_USB_16 ?
I already use :
the PCAN-Status Display, to remove "dead" clients from the PCAN networks (use right mouse click).
The problem is that the action kills the other parameters
Just need to delete the number3(PCANLight_USB_16)
Thank for help
Re: Default on PCAN-USB
Post by PEAK-Support » Mon 8. Jun 2020, 08:32
Looks like you run PCAN-View or any other on the PCAN-Basic based Application - these application generate their NET dynamically - startet with "PCANLight_USB_16" for teh first USB Hardware.
Simply close all other Applications that use the CAN Interface and try again - also move your used Nets to the Hardware - drive_500 and ucap_500 are shiftet to the virtual CAN of this device.
