LINUX pcan-view OFFLINE install
Ales1000
Post by Ales1000 » Wed 24. Jun 2020, 15:28
I would like to ask you, if it is possible to install pcan-view offline on Linux machine (from pcan_view.tar.gz or something like that)? I have Linux machine which cannot be connected to the internet.
Thank you for response.
Ales
Re: LINUX pcan-view OFFLINE install
Post by M.Heidemann » Wed 24. Jun 2020, 16:15
Just download the driver package from here:
http://www.peak-system.com/fileadmin/me ... 0.1.tar.gz
you could use a flash-drive to store the driver installation package and use it offline.
Best regards
Ales1000
Post by Ales1000 » Tue 30. Jun 2020, 09:37
Hello Marvin,
I already installed driver from flash drive. I type "pcan" and press "tab tab" to see available commands, I see no pcan-view. I also have installed pcan-view on Virtual Box, but here, when I type "pcan" and then 2xtab, it shows me pcan-view option. Due to this behavior I expect, that "pcan-view" was not installed.
I install it this way:
tar -xvzf peak-linux-driver-8.10.1.tar.gz
cd peak-linux-driver-8.10.1
sudo make -j4
sudo make install
Should I add some special switches to install pcan-view too?
Ales
Post by M.Heidemann » Tue 30. Jun 2020, 16:05
Hello Ales,
I am sorry, i mixed things up.
The driver package does not contain PCAN-View for Linux.
Pardon me.
Can you give me the output of:
uname -a
I will then send you the appropiate files for your system to install PCAN-View offline.
Ales1000
Post by Ales1000 » Wed 1. Jul 2020, 09:00
Hello Marvin
Output of uname -e command is:
Linux kali 4.9.51-xenomai-3.0.6 #7 SMP PREEMPT Thu Jun 21 00:18:48 CEST 2018 i686 GNU/Linux
Ales
Post by M.Heidemann » Wed 1. Jul 2020, 10:23
Hello Ales,
We unfortunately do not offer an RT version of PCAN-View,
In order to use PCAN-View you would need to use the "regular" PCAN-Linux driver
that was compiled for non-RT environments.
We can send you the .deb package that will work on the non-RT versions of the driver,
if you are interested!
Ales1000
Post by Ales1000 » Wed 1. Jul 2020, 10:33
Hello Marvin,
thank you for information. I would apprecieate pcan-view version for "regular" PCAN-Linux driver.
Thank you.
Ales
Post by M.Heidemann » Wed 1. Jul 2020, 11:32
Hello Ales,
Here is a comrpessed tarball that only contains the 32-bit executable
https://cavok.peak98.de/XnWdUgD
The screenshot below show you the shared libs pcanview needs,
Mainly libncurses and libpthread.
If you do not use any package repos you'll have to handle the dependencies yourself.
This package is provided as is, we did not test this on an environment like yours.
For further questions feel free to contact us again.
Ales1000
Post by Ales1000 » Thu 2. Jul 2020, 10:00
Hello Marvin,
thank you for info. This worked well. I would have some questions.
Do you also have .deb package for installing, or it is only distributed as binary file?
Do you also have PCAN-view for OS: Linux blackbox 4.14.134-xenomai #1 ... 2019 x86_64 GNU/Linux?
Thank you.
Ales
Post by M.Heidemann » Thu 2. Jul 2020, 13:42
Hello Ales,
This package only contains binary files.
If this other OS is also offline, you may want to give me output of:
lsb_release -cs
If you other OS is an online one you can proceed like described on our Linux-Support Page in the scetion "How to install PCAN-View via repository":
