Re: Welcome to the PLIN-LInux Beta Test
aguan.zhang
Post by aguan.zhang » Mon 29. Jun 2020, 11:32
Hi Marvin,
There meet a install error:
$sudo make install
make[1]: Entering directory '/home/zhangaguan/peak-lin-driver-1.0.0/driver'
Installing driver module plin.ko for linux 5.3.0-61-generic:
rmmod: ERROR: Module plin is not currently loaded
Makefile:185: recipe for target 'install_driver' failed
make[1]: [install_driver] Error 1 (ignored)
My Linux OS as follows:
gcc version 7.5.0 (Ubuntu 7.5.0-3ubuntu1~18.04)
GNU Make 4.1
BRs
Aguan
Post by M.Heidemann » Mon 29. Jun 2020, 11:56
Hello Aguan,
Can you please open a new topic regarding this and post your command history ("before sudo make install") there?
aguan.zhang
PLIN-LInux driver Beta Install Error
Post by aguan.zhang » Mon 29. Jun 2020, 12:15
Hi Marvin,
The history commands as below:
zhangaguan@zhangaguan-ThinkPad-T480s:~/peak-lin-driver-1.0.0$ make
Building driver module plin.ko from /usr/src/linux-headers-5.3.0-61-generic,
with cc version 7, under Ubuntu 18.04:
make -C /usr/src/linux-headers-5.3.0-61-generic  EXTRA_CFLAGS="-D'DRV_NAME=\"plin\"'" M=/home/zhangaguan/peak-lin-driver-1.0.0/driver modules
make[2]: Entering directory '/usr/src/linux-headers-5.3.0-61-generic'
  CC [M]  /home/zhangaguan/peak-lin-driver-1.0.0/driver/plin_main.o
  CC [M]  /home/zhangaguan/peak-lin-driver-1.0.0/driver/plin_sysfs.o
  CC [M]  /home/zhangaguan/peak-lin-driver-1.0.0/driver/plin_chrdev.o
  CC [M]  /home/zhangaguan/peak-lin-driver-1.0.0/driver/plin_usb.o
  LD [M]  /home/zhangaguan/peak-lin-driver-1.0.0/driver/plin.o
  Building modules, stage 2.
  MODPOST 1 modules
  CC      /home/zhangaguan/peak-lin-driver-1.0.0/driver/plin.mod.o
  LD [M]  /home/zhangaguan/peak-lin-driver-1.0.0/driver/plin.ko
make[2]: Leaving directory '/usr/src/linux-headers-5.3.0-61-generic'
make[1]: Leaving directory '/home/zhangaguan/peak-lin-driver-1.0.0/driver'
make[1]: Entering directory '/home/zhangaguan/peak-lin-driver-1.0.0/utils'
Building plin utilities:
make[1]: Leaving directory '/home/zhangaguan/peak-lin-driver-1.0.0/utils'
zhangaguan@zhangaguan-ThinkPad-T480s:~/peak-lin-driver-1.0.0$ ls
driver  LICENSE.gpl  LICENSE.lgpl  Makefile  utils
zhangaguan@zhangaguan-ThinkPad-T480s:~/peak-lin-driver-1.0.0$ sudo make install
[sudo] password for zhangaguan:
- Building dependencies...
- Installing driver API header file under /usr/include...
- Reloading Udev rules...
Installing plin utilities under /usr/bin...
cp -f lin linwrite linread /usr/bin
Re: Error on Install
Post by M.Heidemann » Mon 29. Jun 2020, 12:40
Hello aguan,
Please build the driver by just executing:
make
I would recommend to follow the Quick-Start-Guide for now.
Is there any specific reason you want to build the driver like this?
aguan.zhang
Post by aguan.zhang » Mon 29. Jun 2020, 13:33
Hi Marvin,
I build the driver by following the Quick-Start-Guide. and only excuting:
make
sudo make install
no other operation.
BRs
aguan
Post by M.Heidemann » Fri 3. Jul 2020, 08:05
Hello Aguan,
Please stick to one thread if possible, i'll close the redundant one.
can you share to output of:
uname -a
with us?
marvin
aguan.zhang
Post by aguan.zhang » Fri 3. Jul 2020, 08:36
Hi Marvin,
$ uname -a
Linux zhangaguan-ThinkPad-T480s 5.3.0-61-generic #55~18.04.1-Ubuntu SMP Mon Jun 22 16:40:20 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
Install commands:
$ make
make[1]: Entering directory '/home/zhangaguan/PLIN-Linux-Beta-Package/peak-lin-driver-1.0.0/driver'
make -C /usr/src/linux-headers-5.3.0-61-generic  EXTRA_CFLAGS="-D'DRV_NAME=\"plin\"'" M=/home/zhangaguan/PLIN-Linux-Beta-Package/peak-lin-driver-1.0.0/driver modules
  CC [M]  /home/zhangaguan/PLIN-Linux-Beta-Package/peak-lin-driver-1.0.0/driver/plin_main.o
  CC [M]  /home/zhangaguan/PLIN-Linux-Beta-Package/peak-lin-driver-1.0.0/driver/plin_sysfs.o
  CC [M]  /home/zhangaguan/PLIN-Linux-Beta-Package/peak-lin-driver-1.0.0/driver/plin_chrdev.o
  CC [M]  /home/zhangaguan/PLIN-Linux-Beta-Package/peak-lin-driver-1.0.0/driver/plin_usb.o
  LD [M]  /home/zhangaguan/PLIN-Linux-Beta-Package/peak-lin-driver-1.0.0/driver/plin.o
  MODPOST 1 modules
  CC      /home/zhangaguan/PLIN-Linux-Beta-Package/peak-lin-driver-1.0.0/driver/plin.mod.o
  LD [M]  /home/zhangaguan/PLIN-Linux-Beta-Package/peak-lin-driver-1.0.0/driver/plin.ko
make[1]: Leaving directory '/home/zhangaguan/PLIN-Linux-Beta-Package/peak-lin-driver-1.0.0/driver'
make[1]: Entering directory '/home/zhangaguan/PLIN-Linux-Beta-Package/peak-lin-driver-1.0.0/utils'
gcc lin.c -c -I../driver -o lin.o
gcc   lin.o   -o lin
gcc linwrite.c -c -I../driver -o linwrite.o
gcc   linwrite.o   -o linwrite
gcc linread.c -c -I../driver -o linread.o
gcc   linread.o   -o linread
make[1]: Leaving directory '/home/zhangaguan/PLIN-Linux-Beta-Package/peak-lin-driver-1.0.0/utils'
$ sudo make install
$ sudo modprobe plin
modprobe: ERROR: could not insert 'plin': Operation not permitted
Post by M.Heidemann » Fri 3. Jul 2020, 08:59
Hello Aguan,
Thanks for the Info.
Is secureboot enabled on this system?
This will prevent third-party-modules such as this driver from being loaded.
Please check your BIOS settings and check if secureboot is enabled.
Please report back to me if this was the cause for this.
aguan.zhang
Post by aguan.zhang » Fri 3. Jul 2020, 09:32
Hi Marvin,
It can be loaded successfully after disable the secure boot on Ubuntu 18.
Thanks very much.
BRs
Aguan
Post by M.Heidemann » Fri 3. Jul 2020, 09:34
Hello Aguan,
You're welcome!
- Closed -
