Problem with Write function
MOUHOUBI
Post by MOUHOUBI » Thu 16. Jul 2020, 11:36
I have executed the following code to write a CAN message, it has been initialized (we can see it on the message after debugging) but it can't manage to Write a CAN message it puts the translation in French (system language d 'exploitation) as indicated on the documentation screenshot
the code used is as follows:
from PCANBasic import *        ## PCAN-Basic library import
# The Plug & Play Channel (PCAN-USB) is initialized
objPCAN = PCANBasic()
result = objPCAN.Initialize(PCAN_USBBUS2, PCAN_BAUD_500K)
if result != PCAN_ERROR_OK:
    # An error occurred, get a text describing the error and show it
    result = objPCAN.GetErrorText(result)
    print (result[1])
else:
    print ("PCAN-USB (Ch-1) was initialized")
# All initialized channels are released
#objPCAN.Uninitialize(PCAN_NONEBUS)
# A CAN message is configured
msg = TPCANMsg()
msg.ID = 0x100
msg.MSGTYPE = PCAN_MESSAGE_STANDARD
msg.LEN = 3
msg.DATA[0] = 1
msg.DATA[1] = 2
msg.DATA[2] = 3
# The message is sent using the PCAN-USB Channel 1
result = objPCAN.Write(PCAN_USBBUS1,msg)
# An error occurred, get a text describing the error and #
    print (result)
else:
    print ("Message sent successfully")
# The USB Channel is released
result = objPCAN.Uninitialize(PCAN_USBBUS1)
    print (result[1])
else:
    print ("PCAN-USB (Ch-1) was released")
You have already helped me a lot before thank you very much
Re: Problem with Write function
Post by K.Wagner » Thu 16. Jul 2020, 11:49
if you check the help you will see that you cannot send/receive messages using an uninitialized channel. Moreover, you should also check in the documentation for the error codes you are receiving and check yourself what is going wrong (the codes are very descriptive).
At the end of the first code block you are just uninitializing the channel right after initializing it (and before writing anything).
print (result[1])
else:
PLEASE NOTE: You are just copy/pasting code without understanding what you are doing. Please use the help file as i told you before. Last warning :!:
Taking you by the hand or programming for you is not included in the support service we give.
