Devices not getting displayed under /dev
vijayendranss
Post by vijayendranss » Fri 11. Sep 2020, 08:01
I use PCAN Driver for Linux v8.
Few general queries :
After succesfull compilation when i do execute
sudo modprobe pcan
lspcan -T -t -a
Devices are not getting displayed under /dev
Note : I have not connected actual device or hardware in my PC.
Is it exepcted behavior ?
or
regardless of actual device connection of the devices, those should get displayed ?
Which is expected behavior ?
Re: Devices not getting displayed under /dev
Post by M.Heidemann » Fri 11. Sep 2020, 08:03
This beheaviour is expected. The devices only show up if connected.
vijayendranss
Post by vijayendranss » Fri 11. Sep 2020, 08:24
Hi Marvin,
Thanks for the reply.. But one query.
I used some other LKM. This will create virtual devices under /dev.
I used insmod for this and i can see al lthe devices under /dev.
Infact, modprobe also in turn uses insmod. Why there is different behavior ?
I want somehow the devices to be displayed without connecting. Any suggestions ?
Post by M.Heidemann » Fri 11. Sep 2020, 14:02
Other LKM, can you please clearify which?
Suggestion here would be to take a look at the documentation and have a look at the chapter Udev rules (4.2),as it will show you, what the Udev rules a doing by default.
You can choose not to use Udev and create the devices manually.
Quote from the docuemntation (page 18):
"With a properly configured and running Udev system, all of these devices files and directories are generated on the fly. If the target non-RT system does not have a running Udev system, you must create the device files manually each time after driver installation. The driver package provides the shell script driver/pcan_make_devices for this. For example, to create a maximum of 2 devices of each type"
