PCAN-Explorer Window not visible after startup..
U.Wilhelm
Post by U.Wilhelm » Fri 4. Dec 2020, 15:12
If you work with a Multi Monitor Environment and swap from time to time to differnet settings (Laptop in Home Office etc.) it could be that after PCAN-Explorer start up is not visible on your screens.
That happened when the Software was closed on a position which is in the new environment (Office/Home) not visible / existing.
Please close the PE6 (Task Manager) and hold the "STRG+SHIFT" while you start the Application again.
