Problem while installing PCAN view in Linux Ubuntu OS
nikhil1990
Post by nikhil1990 » Thu 17. Dec 2020, 14:26
Error output while installing PCAN view in ubuntu OS.
PCAN driver 8.10.0 is installed.
Followed below link to install PCAN view
https://www.peak-system.com/produktcd/D ... harDev.txt
Sequence of commands:
If you want to use our PCAN-View for Linux example you need the GTK+2:
$ sudo apt-get install gtk+2.0
$ wget http://www.peak-system.com/cupd2/PCAN-V ... TK+.tar.gz
NOTICE - this download link will no longer available - ask for this file at support@peak-system.com
$ tar -xzf PCAN-View-LINUX-GTK+.tar.gz
$ cd pcanview
$ make all
Error Output:
In file included from /usr/include/PCANBasic.h:32:0,
from src/PCanView.h:46,
from src/TransmitMessages.cpp:19:
/usr/include/pcan.h:32:2: error: #error "double define for DWORD, WORD, BYTE found"
Re: Problem while installing PCAN view in Linux Ubuntu OS
Post by M.Heidemann » Thu 17. Dec 2020, 14:45
This information is deprecated (This document was written when driver version 7.14 was current - 2014).
Please follow the current instructions given on our Linux-support page (Scroll down to the PCAN-View section):
Please also make sure to install the latest PCAN-Linux driver 8.10.2:
http://www.peak-system.com/fileadmin/me ... 0.2.tar.gz
nikhil1990
Post by nikhil1990 » Fri 18. Dec 2020, 07:45
Thanks for your help.
I am using PCAN-Linux driver 8.10.0. Is it fine to continue with the existing version or i need to upgrade to 8.10.2?
Another doubt is i installed PCAN view as per the link shared by you. No want to know how i can launch this PCAN view tool.
Thanks.
Sai
Post by M.Heidemann » Fri 18. Dec 2020, 08:18
We do recommend to use the latest driver available,
we actively fix any bugs and introduce new features
with each and every iteration of the driver.
you can launch pcanview just by calling:
pcanview
from terminal.
Best regards
