Forum for the PCANBasic .NET Assembly Beta-Package containing
the PCANBasic-Assembly developed in .NET-Standard.
ChololateIT
Post
by ChololateIT » Thu 7. Jan 2021, 14:49
I just saw that
is defined as
int while in the "classic" library it's a
byte. Is this a bug and will be changed to byte?
Best regards
- Software Development
Post
by K.Wagner » Fri 8. Jan 2021, 08:55
no it is not a bug, it was intended so. As you can see the classic TPCANMsg structure has also a member LEN of type byte, and in the assembly is defined as int too.
Assembly:
Classic:
The idea is to prevent the user for making castings by himself when working with the assembly. The assembly checks and sends the real data size to the underlying driver. This assembly is thought to do more than the classic library you know; even when it looks most same as the classic API, it could be extended to have other help functions and classes.
