Bitrate information
Mobile diagnostic device for CAN and CAN FD buses with optional J1939 add-in
Mike15
Bitrate information
Post by Mike15 » Wed 3. Mar 2021, 14:22
how should the purple information in the bit trace be interpreted? Could not found anything about it.
Best regards
Mike
Re: Bitrate information
Post by M.Heidemann » Wed 3. Mar 2021, 15:53
Hello Mike,
We assume you are referring to the Oscilloscope-View,
in which case this is refering to bit periods (blue):
The elements of the Oscilloscope-View are described in the PCAN-Diag FD docuementation, chapter
6.1 - Properties of the Oscilloscope Function:
Please let us know, if this has answered your questions.
Mike15
Post by Mike15 » Thu 4. Mar 2021, 08:46
I assume that the blue vertical line mark the sample point, does it?
But what does that purple lines mark? They occur here and there, never within the CRC, at both edges.
purple edges.png (292.71 KiB) Viewed 8439 times
Post by M.Heidemann » Thu 4. Mar 2021, 14:51
These indicate stuff-bits,
you are right, this is missing from the manual.
marvin
Mike15
Post by Mike15 » Thu 4. Mar 2021, 15:48
I see :D ,
thanks.
M.Gerber
Design & Documentation
Post by M.Gerber » Fri 5. Mar 2021, 08:21
This will be documented in the next release of the user manual. Thanks for giving the hint, Mike.
Kind regards
Mark
