PCAN-LIN and PCAN-View
RS-232 to CAN/LIN Interface
efariv
Post by efariv » Fri 9. Apr 2021, 01:34
I have a PCAN-LIN configured as a LIN listener for a master and single slave system. Master Tx is message 0x6, and Rx is message 0x5. I'm able to view all LIN signals via RS232 in the "Messages and Scheduler" tab in PCAN-LIN CT. However I have a PCAN-USB w/ PCAN-View attached to the CAN pins coming out of the PCAN-LIN adapter, and I'm not seeing anything there. I've been following the "Howto_PCAN-LIN_v1.0.0.2" document to configure. I've also attached my pclin file. Could I get some advice?
Eric
P.S. ultimately I'm trying to setup this PCAN-LIN adapter as a LIN Master. To read and write LIN commands to the LIN slave via CAN.
LIN_Listener.pclin
(43.78 KiB) Downloaded 3424 times
Re: PCAN-LIN and PCAN-View
Post by M.Maidhof » Fri 9. Apr 2021, 09:10
your config looks ok, and I am able to see the CAN messages in PCAN-View. Please check that you use a terminated CAN cable between PCAN-LIN and PCAN-USB (120 Ohms on both ends), and that you have set the baudrate in PCAN-View to 500k.
