how to use digital out (Dout)
rixccaptv
Post by rixccaptv » Wed 14. Apr 2021, 03:28
Hi.
I want to install a small buzzer in a vehicle build and control it via the Dout pin.
I did not find any code example of how to set this up (for example, how to set output voltage) and trigger it...
Re: how to use digital out (Dout)
Post by M.Heidemann » Wed 14. Apr 2021, 08:15
Please have a look at the example 03_TIMER_IO, this example
uses a CAN-message to set the low side switch:
// catch ID 334h to control the low-side switch
			if ( RxMsg.id == 0x334  &&  RxMsg.msgtype == CAN_MSGTYPE_STANDARD)
				uint32_t  dig_out;
				// default OFF
				dig_out = 0;
				if ( RxMsg.data8[0] & 1)
					// switch load to GND e.g. relay
					dig_out |= 1;
				HW_SetDOUT ( &dig_out);
			// forward message to CAN2
			CAN_Write ( CAN_BUS2, &RxMsg);
For more information on the digital output please
have a look at the PCAN-Router FD documentation on page 32:
Post by PEAK-Support » Wed 11. Aug 2021, 08:36
Her some additional Information for using the IO´s on the Router FD
The Router FD have 3 IO Pins. They could be used as 1Dout and 2Din, or 3 Din.
reading
Din0 --> Value 1 Read Din0 as High
Din1 --> Value 2 Read Din1 as High
Din2 --> Value 4 Read Din2 as High
write
Dout0 --> Value 1 Set active --> activate low-side switch (pull low)
Dout0 --> Value 0 Set inactive --> de-activate low-side switch
(other values will be ignored)
how to use:
uint32_t  buff, din0, din1, din2;
HW_GetDIN ( &buff);
din0 = ( buff >> 0) & 1;  // bit 0
din1 = ( buff >> 1) & 1;  // bit 1
din2 = ( buff >> 2) & 1;  // bit 2
For HW_SetDOUT() only bit 0 is used.
uint32_t  buff;
// activate low-side switch (pull low)
buff = 1;
HW_SetDOUT ( &buff);
// de-activate low-side switch (high-Z)
buff = 0;
rixccaptv
Post by rixccaptv » Mon 13. Dec 2021, 10:42
Thank you.
My doubt is resolved and I'm able to use the Dout now. :)
