Communicate with single wire vehicle bus system
LIN Interface for USB
Steve
Post by Steve » Wed 19. May 2021, 21:03
actually I'm looking for a device, which is capable to communicate with a 12 V single wire vehicle bus system.
Unfortunately I'm not 100 % sure if it's really a LIN-compatible bus system. Please see attachment, where I recorded one master message and the slave response. This repeats then every 100 ms.
Bus message.PNG (33.99 KiB) Viewed 4897 times
If this is not a LIN-Bus, would it be anyways possible to use PLIN-USB interface as a slave device in this bus system?
Basic task is to wait for the master message and then send a pre-definded (recorded) slave message.
Thank you in advance!
BR
Steve
Re: Communicate with single wire vehicle bus system
Post by M.Maidhof » Thu 20. May 2021, 08:03
Hi Steve,
this signal does not look like a LIN bus nor a CAN bus signal. This looks like a PWM signal. So it will not be possible to use the PLIN-USB for such a signal. Who is the manufacturer of the vehicle with those bus signals?
Steve
Post by Steve » Thu 20. May 2021, 09:14
Hello Michael,
this is a 2018 Subaru WRX STI .
It's the communication between seat occupancy sensor/control unit and airbag control unit.
Do you have any other device, which is able to "simulate" slave response?
BR
Steffen
Post by M.Maidhof » Thu 20. May 2021, 10:54
no, we don't offer any devices which are able to simulate such signals.
