using pcan lib in visual studio code
USB to CAN Interface
alankrita_asthana
Post by alankrita_asthana » Thu 27. May 2021, 11:52
hello ,
i would like to add PCAN lib and use it in Visual studio Code using c++.
i am unable to understand in which folder should i add the pcan lib that i downloaded from the peakcan website.
it would be great if you can tell me how can i do it using cmd prompt or in which folder of my VS code folder should i place the PEAKcan lib folder so that i can direct use the liv through c++ in VS code.
it would be great if you could describe the process step by step or suggest a video or some tutorial.
Thanks & regards,
Alankrita.
Re: using pcan lib in visual studio code
Post by PEAK-Support » Thu 27. May 2021, 12:14
As we do not have the needed information we are unable to help you.
Visual Studio Code is a EDITOR
Which OS ?
Which API ?
Which HW ?
Basic´s in environment setup for developer tools are not handled from us via technical support
