Set Interrupt Event Handler
hello
To simply my main loop, I would like to create an EventHandler
on a Timer (eg: every 10 ms) (TIMER0_IRQ ?)
and RS232 (UART0_IRQHandler ?)
but I don't have any example or doc to handle it:
I see on startup_ARMCM4.c
all IRQ are setted to Default Handler (while(1))
eg :
void TIMER0_IRQHandler (void) __attribute__ ((weak, alias("Default_Handler")));
did you already implement any function that allows me to handle a ticker and RS232 reception , or should I directly modify this file ?
eg :
Re: Set Interrupt Event Handler
We have relayed your request to our development-team and we will report back
to you with more information regarding this.
We have received feedback from our development team:
In case of the RTC you could define your own interrupt handler, which will
overwrite the default handler:
For the RS-232 Interrupts the procedure is similar, you will however
need to make sure that you use a custom name for the handler, as "UART0_IRQHandler " does exist
in the lib (UART0_IRQHandler .a) and will cause conflicts.
In both instances we highly recommend to refer to the documentation for
the used NXP LPC4078.
void TIMER0_IRQHandler ( void)
//Your Code
Thank you very much for your rapid answer and complet one
clearly I means that I need to update the startup_ARMCM4.c with my Interrupt program name?
How should I set the timeElapsed (10ms) for IRQ Timer?
I just need to know With IRQ number (UART0?) is assign to the PCAN RS232 serial port ?
you said you handle IRQ UART0, did you do sth which I need to take care of it ?
I will check back with our developer regarding this and will
report back to you with the appropiate information.
After getting back with our developers, i can say the following:
UART0_IRQHandler
replace with (for Example)
UART0_User_IRQHandler
You will of course need to configure the Interrupt , etc,
as this is not handled from the lib anymore at this point.
// uart config
LPC_UART0->LCR = 1 << 7; // set DLAB
LPC_UART0->DLL = reload;
LPC_UART0->DLM = reload >> 8;
// IRQ enable
NVIC_EnableIRQ ( UART0_IRQn);
For the timer interrupt implementation, you'll also have to declare your own interrupt for it.
You can take a look at example "03_timer" for reference.
Also, have a look at the reference manual for LPC408x/407x, as most of this
documented in the reference manual:
https://www.nxp.com/docs/en/user-guide/UM10562.pdf
Yes, you will have to replace this with your interrupt handler :clearly I means that I need to update the startup_ARMCM4.c with my Interrupt program name?
UART0_IRQHandler
// uart config
// IRQ enable
hello
thank you for your feed back ,
regarding irq_timer every 10ms (like tick), NXP document propose to overload the method sysTick_handler(). I saw you propose a "weak" implementation in statup_ARMCM4.c file
may i wrong if I implement the tick like this ?
kind regards
void (*sysTimeIRQ) (void) ;
void init_sysTick(uint32_t timeMs)
SysTick_Config(SystemCoreClock /(timeMs) );
void SysTick_attach (void (*fct)(void),uint32_t timeMs)
init_sysTick(timeMs);
sysTimeIRQ = fct;
void SysTick_Handler ()
{ sysTimeIRQ();
We do not support the LPC408x/407x platform directly.
Our implementation may differ from yours, feel free to us another implemenation
better suited for your application.
We'd recommend to get involved with a community speclialized in development
for these platforms, we provide support for devices, which happen to use this microcontroller.
Once we talk about certain implementations of fucntions on LPC408x/407x itself,
this goes beyond the scope of support that we can provide.
Thanks à lot got it
