incompatible firmware
dmedore
Post by dmedore » Wed 9. Jun 2021, 05:36
I have successfully compiled code, but when trying to flash the firmware using PEAK-Flash it tells me that the firmware is incompatible
I am able to successfully compile and flash other projects that I have created. So what causes the firmware to be incompatible?
Re: incompatible firmware
Post by M.Heidemann » Wed 9. Jun 2021, 09:35
have you deleted/Changed the following line in main.c?:
Also, are you sure you have the right hadware-example as a basis?
dmedore
Post by dmedore » Wed 9. Jun 2021, 13:19
Thanks! I got careless when deleting some of the example code, adding that back in resolved the issue.
Post by M.Heidemann » Wed 9. Jun 2021, 13:51
Thank you for letting us know!
StefKCPerformance
Post by StefKCPerformance » Tue 24. Oct 2023, 14:42
I also have the problem that I get the message "Incompatible firmware". I have not deleted that line of code, however it is red underneath, i also get red messages from the crc_data.h. I think these things are related....Can somebody help me out?
Post by M.Maidhof » Tue 24. Oct 2023, 16:02
please post a screenshot of the problem, showing which device you want to flash. Next, please compile one of our examples and try to flash it to your PCAN-Router FD. Does it show the same problem?
StefKCPerformance
Post by StefKCPerformance » Tue 24. Oct 2023, 16:17
I have not written my own code yet, I was trying to put different examples on it for learning how it works, but even those don't work. I have the CAN TO USB adapter and the PCAN-Router (IPEH-002210-P 05525). Hope you understand my problem, if not please let me know.
Schermafbeelding 2023-10-24 161507.png (211.55 KiB) Viewed 11143 times
Post by PEAK-Support » Tue 24. Oct 2023, 22:44
If you follow the instructions in the package, you will get it work.
X hundreds of customers get it work, so why should it not work on your system.
Without seeing the compiler / linker output etc. we are not able to give you some help… sorry…
StefKCPerformance
Post by StefKCPerformance » Fri 27. Oct 2023, 11:06
I have tried to install the devpack according to the manual twice, but I still encounter the same issues where a significant portion of my code components are not recognized. From my perspective, there isn't much explanation beyond extracting the file to a local directory and running the VSCode file. The only part that doesn't work for me is executing the 'make' command via the terminal of VS Code. However, I am able to run the 'Make' command using CDM, and I get files in the .out directory with no error messages. I came across these instructions in the PCAN Router Documentation. Only when I try to upload it to my PCAN Router via the Flash software, I receive a message stating that my file is not compatible. Do you have any idea what might be causing this issue? Thank you in advance, Stef.
Post by PEAK-Support » Fri 27. Oct 2023, 11:11
We do not know what exact you do different to x hundred other customers - where it work.
So we are sorry, always posting "it do not work" without any real and useful outputs is not very helpfullly...
So sorry - no we do not know what you do different / wrong.
We have a Video that shows the single steps - maybe that explains it better for you.
! Take care that, when using the PEAK-Flash Tool, that you want to flash a Device that is connected to the CAN Bus - not a local Device !
Screenshot 2023-10-27 112608.png (7.96 KiB) Viewed 11096 times
