PLIN Viewer Pro - communication MASTER-SLAVE problem
Ales1000
Post by Ales1000 » Thu 12. Aug 2021, 10:14
I have problem with PLIN viewer (see attachment) on PCAN-USB Pro FD. When I press space button on MASTER part, data are sent but not come filled, also checksums aredifferent. When I use slave created programatically and MASTER from PLIN viewer, it works fine. Where can be the problem?
Thank you in advance.
Aleš
Re: PLIN Viewer Pro - communication MASTER-SLAVE problem
Post by M.Maidhof » Thu 12. Aug 2021, 11:10
please show the properties for ID 0x01 on the master and slave side.
Ales1000
Post by Ales1000 » Thu 12. Aug 2021, 11:13
here it is shown.
Aleš
Post by M.Maidhof » Thu 12. Aug 2021, 12:07
looks like you missed the LIN voltage supply on the master side. Would be helpfull to resize the master receive window to see the errors.
Ales1000
Post by Ales1000 » Thu 12. Aug 2021, 12:13
You are right. How is it possible? I run this on one PCAN USB Pro FD device.
Aleš
Ales1000
Post by Ales1000 » Thu 12. Aug 2021, 12:17
It was maybe caused by current limit on source. I increased voltage and current limit and receiving this. Slave is not doing what I expected. It did not fill data. Do you now what is problem here?
Post by M.Maidhof » Thu 12. Aug 2021, 12:19
See manual page 12:
Next problem: you did not send the publisher frame on the slave side. Hit the space bar to send the publisher frame to the slave hardware channel (count is 0 in your screenshot).
Ales1000
Post by Ales1000 » Thu 12. Aug 2021, 13:03
Yes, I have interconnected both CANNONs by cable and on pin 6 and 9 is supply voltage, so both CANNONs are connected to same supply source.
Why it is needed to send frames as a slave? Slave is not allowed to send frames alone, he needs to be requested by master, right? How many times I have to send frame as slave, from my experiment I found out, that it is possible to "active" slave by one hit.
Aleš
Post by M.Maidhof » Thu 12. Aug 2021, 13:19
To modify the publisher data of a slave node, you have to send a publisher frame in the slave publisher window, as you did it before in your first screenshot.
