Registering a PLIN collision event resolution schedule
hazime
Post by hazime » Mon 16. Aug 2021, 09:06
Hello, thank you.
I'm having trouble registering a resolution schedule
Schedule 1 cannot be registered
ret2 is 0x08 error
Help me.
#include <iostream>
#include "conio.h"
#include "windows.h"
#include "PLinApi.h"
#define ESC 27
#define LIN_INTERFACE_ID 0
//#define CHECKSUM_TYPE cstClassic
#define CHECKSUM_TYPE cstEnhanced
HLINHW getLINHardware()
	HLINHW LINHardwareBuffer[10];
	int count;
	HLINHW result = -1;
	if (errOK == LIN_GetAvailableHardware(LINHardwareBuffer, (sizeof(HLINHW) * 10), &count))
		for (int cnt = 0; cnt < 10; cnt++)
			char hardwareName[64];
			int idNumber;
			memset(hardwareName, 0x00, sizeof(hardwareName));
			LIN_GetHardwareParam(LINHardwareBuffer[cnt], hwpName, hardwareName, sizeof(hardwareName));
			LIN_GetHardwareParam(LINHardwareBuffer[cnt], hwpIdNumber, &idNumber, sizeof(idNumber));
			// Hardware NamerとIDが合致するPLIN-USBインターフェースを使用する
			if ((0 == strcmp(hardwareName, "PLIN-USB")) && (LIN_INTERFACE_ID == idNumber))
				// 使用LINインターフェース
				result = LINHardwareBuffer[cnt];
				break;
	return result;
HLINCLIENT openLINDevice(HLINHW LINHardware)
	HLINCLIENT result = -1;	// Client
	// LIN Clientの名称作成
	char clientName[LIN_MAX_NAME_LENGTH];
	memset(clientName, 0x00, sizeof(clientName));
	sprintf_s(clientName, "LINClient_%d", LIN_INTERFACE_ID);
	// LIN Clientの登録
	LIN_RegisterClient(clientName, NULL, &result);
	std::cout << "<Ok> LIN_RegisterClient" << std::endl;
	// LIN ClientとHardwareの接続
	LIN_ConnectClient(result, LINHardware);
	std::cout << "<Ok> LIN_ConnectClient" << std::endl;
	// LINハードウェアの初期化
	LIN_InitializeHardware(result, LINHardware, modMaster, 9600);
	std::cout << "<Ok> LIN_InitializeHardware" << std::endl;
	LIN_ResetClient(result);
	return result;
void setTargetFrame(HLINCLIENT client, HLINHW hardware)
	DWORD ret;
	LIN_RegisterFrameId(client, hardware, 0, 63);
	TLINFrameEntry tLINFrame;
	memset(&tLINFrame, 0x00, sizeof(TLINFrameEntry));
	tLINFrame.FrameId = 0x10;
	tLINFrame.Length = 2;
	tLINFrame.Direction = dirSubscriber;
	tLINFrame.ChecksumType = CHECKSUM_TYPE;
//	tLINFrame.Flags = FRAME_FLAG_RESPONSE_ENABLE;
	ret = LIN_SetFrameEntry(client, hardware, &tLINFrame);
	printf("0x10=%d\n", ret);
	tLINFrame.FrameId = 0x11;
	printf("0x11=%d\n", ret);
	tLINFrame.FrameId = 0x12;
	printf("0x12=%d\n", ret);
	tLINFrame.FrameId = 0x13;
	tLINFrame.Direction = dirPublisher;
	tLINFrame.InitialData[0] = 0x13;
	tLINFrame.InitialData[1] = 0x13;
	printf("0x13=%d\n", ret);
void setSchedule(HLINCLIENT client, HLINHW hardware)
	TLINScheduleSlot mainSchedule[2];
	mainSchedule[0].Type = sltUnconditional;
	mainSchedule[0].Delay = 32;
	mainSchedule[0].FrameId[0] = 0x10;
	mainSchedule[0].CountResolve = 1;
	mainSchedule[1].Type = sltUnconditional;
	mainSchedule[1].Delay = 32;
	mainSchedule[1].FrameId[0] = 0x13;
	DWORD ret1 = LIN_SetSchedule(client, hardware, 0, mainSchedule, 2);
	printf("ret1=%d\n", ret1);
	TLINScheduleSlot resolvSchedule[2];
	resolvSchedule[0].Type = sltUnconditional;
	resolvSchedule[0].Delay = 16;
	resolvSchedule[0].FrameId[0] = 0x12;
	resolvSchedule[1].Type = sltUnconditional;
	resolvSchedule[1].Delay = 16;
	resolvSchedule[1].FrameId[0] = 0x11;
	DWORD ret2 = LIN_SetSchedule(client, hardware, 1, resolvSchedule, 2);
	printf("ret2=%d\n", ret2);
	LIN_StartSchedule(client, hardware, 0);
void terminate(HLINCLIENT client, HLINHW hardware)
	LIN_ResetHardwareConfig(client, hardware);
	LIN_DisconnectClient(client, hardware);
	LIN_RemoveClient(client);
int main()
	HLINHW targetInterface = getLINHardware();
	HLINCLIENT client = openLINDevice(targetInterface);
	setTargetFrame(client, targetInterface);
	setSchedule(client, targetInterface);
	while (1) {
		if (_kbhit() && _getch() == ESC) {
			_cputs("\r\nYou Hit Esc-Key!!\r\n");
			break;
	terminate(client, targetInterface);
Re: Registering a PLIN collision event resolution schedule
Post by M.Heidemann » Mon 16. Aug 2021, 12:47
Hello Hazime,
Thank you for your request.
You'll need to fully initialize your arrays,
the behaviour for reading unitialized arrays is undefined.
Some languages will default to known values such as 0, but this is not the case
with C++ instead any value occupying that memory address will be the default value,
as this is unpredictable, this could either work or not depending on the situation.
(This could also lead to really bad issues later on, as this - in some instances - can
pass multiple tests and then completely fail in production)
You should do the following corrections:
	TLINScheduleSlot mainSchedule[2] = {0};
	TLINScheduleSlot resolvSchedule[2] = {0};
Please report back to us, if this resolved your problem.
hazime
Post by hazime » Tue 17. Aug 2021, 11:15
Thank you Marvin.
Schedule 1 has been registered.
However, it was not switched to the "resolving schedule" at the time of the collision.
Are there any settings that are missing when registering the "resolving schedule"?
PLIN-USB x 3
Master, slave 1, slave 2
Master is the modified source
slave1
#include <iostream>
#include "conio.h"
#define ESC 27
#define LIN_INTERFACE_ID 1
	int count;
	HLINHW result = -1;
			int idNumber;
				// 使用LINインターフェース
				break;
	return result;
	// LIN Clientの名称作成
	// LIN Clientの登録
	// LINハードウェアの初期化
	LIN_InitializeHardware(result, LINHardware, modSlave, 9600);
	return result;
	tLINFrame.InitialData[0] = 0x01;
	tLINFrame.InitialData[1] = 0x10;
	tLINFrame.InitialData[0] = 0x11;
	tLINFrame.InitialData[1] = 0x11;
	BYTE RemapTable[64];
	for (int cnt = 0; cnt <= LIN_MAX_FRAME_ID; cnt++)
		RemapTable[cnt] = cnt;
	RemapTable[0x11] = 0x10;
	LIN_SetResponseRemap(client, hardware, RemapTable);
int main()
	while (1) {
			break;
[/list]
slave2
[list]
#include <iostream>
#include "conio.h"
#define ESC 27
#define LIN_INTERFACE_ID 2
	int count;
	HLINHW result = -1;
			int idNumber;
				// 使用LINインターフェース
				break;
	return result;
	// LIN Clientの名称作成
	// LIN Clientの登録
	// LINハードウェアの初期化
	return result;
	tLINFrame.InitialData[0] = 0x02;
	tLINFrame.InitialData[0] = 0x12;
	tLINFrame.InitialData[1] = 0x12;
	RemapTable[0x12] = 0x10;
int main()
	while (1) {
			break;
Reason: Please use "Code"-tags when posting code
Post by M.Heidemann » Tue 17. Aug 2021, 13:05
Dear Hazime,
You defined the schedule-slot responsible for triggering the Resolve-Scheduler
as unconditional, however a collison will be given by an event frame, so in order
to have the resolve schedule triggered you will need to change the Schedule-Slot type,
this is also mentioned in the docuemntation of PLIN-API:
In the last code you have shared with us, the slot responsible for triggering
the ResolveScheduler was still set as unconditional:
Change the slot type to sltEvent and try again.
hazime
Post by hazime » Wed 18. Aug 2021, 03:20
Thank you Marvin.
As you said, setting it to "sltEvent" switched to a resolution schedule.
Thank you so much to help me.
Post by M.Heidemann » Wed 18. Aug 2021, 08:27
Hello Hazime,
Thank you for your feedback!
-closed-
