Im running the NETDEV SUPPORT version with my PEAK adapter on Ubuntu 18.04 to capture CAN packets. I'm using the following commands:
sudo modprobe peak-usb
sudo ip link set can0 up type can bitrate 250000
sudo ip link set up can0
After running this for a couple weeks on my PC and no other programs I get "Filesystem root low disk space". Other forums suggest that the logs are being stored somewhere. Any ideas on how to fix this?
Re: Filesystem root low disk space
One would assume that you do more than:
to capture CAN traffic, so can tell us the exact command (with parameters) used
for capturing?
Furtermore, how much disk-space is there to begin with?
for capturing?
I'm running a basic logging script in an azure container on the Ubuntu PC:
import logging
import time
import can
import j1939
logging.getLogger('j1939').setLevel(logging.DEBUG)
logging.getLogger('can').setLevel(logging.DEBUG)
def on_message(priority, pgn, sa, timestamp, data):
"""Receive incoming messages from the bus
:param int priority:
Priority of the message
:param int pgn:
Parameter Group Number of the message
:param int sa:
Source Address of the message
:param int timestamp:
Timestamp of the message
:param bytearray data:
Data of the PDU
print("PGN {} length {}".format(pgn, len(data)))
def main():
print("Initializing")
# create the ElectronicControlUnit (one ECU can hold multiple ControllerApplications)
ecu = j1939.ElectronicControlUnit()
# Connect to the CAN bus
# Arguments are passed to python-can's can.interface.Bus() constructor
# (see https://python-can.readthedocs.io/en/stable/bus.html).
ecu.connect(bustype='socketcan', channel='can0')
# ecu.connect(bustype='kvaser', channel=0, bitrate=250000)
# ecu.connect(bustype='pcan', channel='PCAN_USBBUS1', bitrate=250000)
# ecu.connect(bustype='ixxat', channel=0, bitrate=250000)
# ecu.connect(bustype='vector', app_name='CANalyzer', channel=0, bitrate=250000)
# ecu.connect(bustype='nican', channel='CAN0', bitrate=250000)
# subscribe to all (global) messages on the bus
ecu.subscribe(on_message)
time.sleep(120)
print("Deinitializing")
ecu.disconnect()
if __name__ == '__main__':
main()
Reason: Please insert <code></code> tags when posting code, this improves readability.
This is uses the logging module of python-CAN.
We are not affiliated with Python-CAN in any capacity and cannot provide you
support. Please contact the Python-CAN community regarding this issue.
