PUSH BUTTON TO SEND TX MESSAGES CONTINUOUSLY
rjrodrig6
Post by rjrodrig6 » Fri 17. Sep 2021, 00:26
Hello Forum,
I am new to this tool, and I am trying to create a simple gui. In the instrument panel, when a button is pushed, I want to mimic what the TransmitMessage object does. Send the message every 100msec. The ValueEdit controller is able to pull all my signals from our custom symbol files that decodes the bytes into legible signals and values.
1. I have a button called Drive Mode, and its execute command property is set to btn_DriveMode_Click() (this is the sub in the vbscript that gets called on button press)
The code below blinks the LED, but does not send anything. The PCAN Explorer windows, specifically Transmit, if I check the tickbox for cycle time, it sends it repeatedly 100msec. I want to replicate that with the push of a button. When button STOP is pressed, we stop sending messages. When a different button is pressed, a different message is send continuously. The idea is press buttons and send different messages depending on which button was pressed, pressing stops, stops sending the messages.
Any idea how I can do this programmatically?
In VBscript I have started with, it does nothing other than enable an LED in Flashmode by setting its threshold greater than 5. Also, I don't know the proper way to access the controls/LED/indicators from VBscript. Sometimes I see examples using the "Signals()" command, and when I try it, the tools complains. So I am not yet clear how to access GUI objects properties etc..
 Sub btn_DriveMode_Click()
	'Dim ObjPanel, ObjLED, ObjCtrl, SigLED, SigCtrl
	Dim i, SigStop, msg, TxVal
	'Get the objects on the panel
	Set ObjPanel = Documents("TESTPANEL.ipf").ActiveWindow.Object		'Selects the active Panel
	Set ObjLED = ObjPanel.ActiveScene.Controls("led_DriveMode")			'Selects the LED Indicator
	Set ObjCtrl(0) = ObjPanel.ActiveScene.Controls("ctrl_BMS_State")		'Selects the control ctrl_BMS_State
	Set SigLED = Signals("LED_DM")												'Selects the Signal Name for the LED Indicator
	Set SigCtrl = Signals("distributed_60B1.cmd_state.cmd_00_state_trans")		'Selects the Signal in the controller
	Set SigStop = Signals("Stop")
	SigStop.Value = 0
	'Set the LED threshold, flashing value, and value to greater than 5 for blinking LED
	ObjLED.threshold = 5
	ObjLED.Flashing = True
	SigLED.Value = 10
	ObjCtrl.CycleTime = 100
	Set TxVal = Signals("TransmitValue")  'Created a sym file with ID, Len, CycleTime=100, and Var=TransmitValue unsigned 0,8 /max:254
	'WaNT TO SEND THE MESSAGE 5 times
	i = 0
	while (i < 5) or (SigStop.Value > 0)
		TxVal = "BMS_STATE_STANDBY"
		i = i + 1
		wait(100)
	wend
End Sub
Re: PUSH BUTTON TO SEND TX MESSAGES CONTINUOUSLY
Post by M.Heidemann » Fri 17. Sep 2021, 09:38
You have already contacted our support via email.
Please stick to one method of communication.
-closed-
