Standard firmware missing in new dev package
Universal CAN Converter in DIN Rail Plastic Casing
O.Hartkopp
Post by O.Hartkopp » Sun 31. Oct 2021, 14:55
The original firmware (253744 Mai 16 2013 example_can.bin) which could be found in the "Development package for PCAN-Router DR (outdated)" in the directory 'Standard firmware' is missing in the new "Development package for ARM-based products" in the Hardware/PCAN-Router_DR section.
Maybe it should be added again in one of the next releases of the new dev package ;-)
Re: Standard firmware missing in new dev package
Post by PEAK-Support » Fri 12. Nov 2021, 10:36
We will check this and maybe exchange the Sample 01_Routing with the delivery Firmware (nearly 1:1 the same source code)
But for now, here the BIN File for flashing the delivery firmware back to the unit
Router_DR_Firmware.zip
Delivery Firmware PCAN-Router_DR
(5.42 KiB) Downloaded 13813 times
O.Hartkopp
Post by O.Hartkopp » Fri 12. Nov 2021, 17:49
Thanks Uwe!
Being able to build the original firmware from source is even cooler!
Oliver
