Can one PCAN-USB Pro FD replace two PCAN-USB FDs in my scenario?
ianasran
Post by ianasran » Tue 18. Jan 2022, 11:49
I am originally testing CAN and CAN FD communication(especially testing the 'converters' in between) using the following architecture with 2 "PCAN-USB FD"s.
Original Test Architecture.jpg (66.17 KiB) Viewed 9728 times
I am considering purchasing ONE "PCAN-USB Pro FD" to replace the above testing with two "PCAN-USB FD"s. I assume it has 2 channels so it is workable. Does it work?
New Test Atchitecture.jpg (86.67 KiB) Viewed 9728 times
Thank you really much.
Sincerely,
Tiffany
Re: Can one PCAN-USB Pro FD replace two PCAN-USB FDs in my scenario?
Post by M.Heidemann » Tue 18. Jan 2022, 11:53
The channels of a PCAN-USB Pro FD are independent for one another, so it's
basically the same as using two PCAN-USB FDs-
So yes, that should be possible.
