How to use error-generator using PCAN-USB
Rishikesh
Post by Rishikesh » Thu 17. Mar 2022, 11:34
I am facing some issues in generating CAN Errors using PCAN FD.I will elaborate what I have tried,
I tried by corrupting the bits in Error Generator Tab.(Using PCAN FD Frame Analyser I got the Bit positions).Whenever I corrupt the data bits in data Region I am getting Stuff error, Whereas in CRC Region I am getting FORM Error as per my understanding I should the CRC Error But I am getting the Form Error. In the meantime I tired corrupting the CRC Delimiter I was expecting FORM Error but I am getting no error frames.
Can anyone help me how to generate All 5 CAN errors using PCAN ?
Thanks in Advance
Rishikesh G
Rishikesh
Re: How to Generate Can Errors Using PCAN
Post by Rishikesh » Thu 17. Mar 2022, 12:51
I am using
PCAN Serial Number:IPEH-004022-020275
PCAN Driver and Build Info:
PCAN_USB 4.2.3.16490
(KMDF 1.9, x64, Desktop)
OS: Windows 10
Reason: Removed citation from previous post
Post by M.Maidhof » Thu 5. May 2022, 09:29
please have a look on the attached pdf guide on how to generate Errorframes with PCAN-View.
Error-Generator_UserGuide_eng.pdf
(703.41 KiB) Downloaded 1477 times
sharika_kumar
Post by sharika_kumar » Mon 21. Aug 2023, 01:10
How do I install Error Generator? I had downloaded PCAN-View from here - https://www.peak-system.com/PCAN-View.242.0.html?&L=1, but cant find this tab
sharika_kumar
Post by sharika_kumar » Mon 21. Aug 2023, 01:13
I cant find Error Generator under "View"
Post by M.Maidhof » Mon 21. Aug 2023, 07:34
this option is only available when you use a PCAN-FD PC hardware. Please post a photo of your used PCAN hardware to see which version you use.
sharika_kumar
Post by sharika_kumar » Fri 25. Aug 2023, 14:05
Part number is G01303-00
Post by M.Maidhof » Fri 25. Aug 2023, 14:24
this is not a PEAK interface number. Please note that is illegal to use our software drivers and PCAN-View with a non PCAN PC interface! Please post a photo of the used hardware.
sharika_kumar
Post by sharika_kumar » Fri 25. Aug 2023, 14:59
This is a legally purchased HW
Post by PEAK-Support » Fri 25. Aug 2023, 15:47
But no original label - so it is not a PEAK-Part number that you send us. It is a IPEH-002021 PCAN-USB - first Generation, and these do not support the Busload and Error Frame Generation.
This is only possible with the CAN FD Devices (see Michaels post in this thread)
We do not know where you buy this part, but adding such a faulty label, looks not like order from an officially reseller from PEAK.
