We are having issues shutting down our Java programs when using the PCANBasic API. We are using PCAN's PCI Quad CAN and M.2 devices on Ubuntu 20.04.2 LTS (Different Computers). We are running with the PREEMPT RT Patch and using PCAN-Basic_Linux-4.5.2 and peak-linux-driver-8.13.0. I think we are having a similar issue mentioned here: viewtopic.php?f=119&t=5980&p=13945&hili ... ize#p13945.
When we press ctrl+c the program stops some of the other java threads, but the PCAN Native Library seems to hang and the program never dies. If we call Uninitialize it also just hangs in the native layer. Currently the only two ways we can successfully stop the program is to Ctrl+Z then pkill the java process or call System.exit(0). I've attached the code below.
Please let me know if you have any ideas or need me to run any tests.
Thank you!
brandon
package us.ihmc.teststands;
import gnu.trove.map.hash.TIntObjectHashMap;
import peak.can.basic.*;
import us.ihmc.commons.Conversions;
import us.ihmc.realtime.*;
import us.ihmc.robotDataLogger.YoVariableServer;
import us.ihmc.robotDataLogger.logger.DataServerSettings;
import us.ihmc.robotics.math.functionGenerator.YoFunctionGenerator;
import us.ihmc.tMotorCore.CANMessages.TMotorCANReplyMessage;
import us.ihmc.tMotorCore.TMotor;
import us.ihmc.tMotorCore.TMotorLowLevelController;
import us.ihmc.tMotorCore.TMotorVersion;
import us.ihmc.yoVariables.registry.YoRegistry;
import us.ihmc.yoVariables.variable.YoBoolean;
import us.ihmc.yoVariables.variable.YoDouble;
import us.ihmc.yoVariables.variable.YoInteger;
import us.ihmc.yoVariables.variable.YoLong;
import java.util.HashMap;
import static peak.can.basic.TPCANStatus.PCAN_ERROR_QRCVEMPTY;
public class TMotorTestBed extends RealtimeThread
private final YoRegistry registry = new YoRegistry(getClass().getSimpleName());
private final YoVariableServer yoVariableServer;
private static final double DT = 0.001;
private static final MonotonicTime period = new MonotonicTime(0, Conversions.secondsToNanoseconds(DT));
private final static PriorityParameters controllerPriority = new PriorityParameters(PriorityParameters.getMaximumPriority() - 5);
private final YoLong tickStartTimeInNanos = new YoLong("tickStartTimeInNanos", registry);
private final YoLong doControlTime = new YoLong("doControlTime", registry);
private final YoLong computeTime = new YoLong("computeTime", registry);
private final YoLong canReadTime = new YoLong("canReadTime", registry);
private final YoLong canWriteTime = new YoLong("canWriteTime", registry);
private final YoLong effectiveDT = new YoLong("effectiveDT", registry);
private final YoDouble yoTime = new YoDouble("yoTime", registry);
private final YoLong readErrorCounter = new YoLong("readErrorCounter", registry);
private final YoLong writeErrorCounter = new YoLong("writeErrorCounter", registry);
private final YoBoolean running = new YoBoolean("running", registry);
// motors in CAN bus
private final TIntObjectHashMap<TMotor> motors = new TIntObjectHashMap<>();
private int[] motorIDs;
private static final int RIGHT_HIP_CAN_ID = 2;
private static final int KNEE_CAN_ID = 11;
private final HashMap<TMotor, TMotorLowLevelController> motorControllers = new HashMap<>();
private final YoFunctionGenerator functionGenerator;
// CAN-related goodies
private PCANBasic can = new PCANBasic();
private final TPCANHandle channel = TPCANHandle.PCAN_PCIBUS1;
private final TPCANMsg receivedMsg = new TPCANMsg();
private TPCANStatus status = null;
// specialized YoVariables
private final YoBoolean enableCANMsgs = new YoBoolean("enableCANMsgs", registry);
private final YoBoolean resetCounters = new YoBoolean("resetCounters", registry);
// debug
private final YoInteger messagesInReadBus = new YoInteger("messagesInBus", registry);
public TMotorTestBed(YoVariableServer yoVariableServer)
super(controllerPriority, new PeriodicParameters(period));
CPUDMALatency.setLatency(0);
initializeCAN();
this.yoVariableServer = yoVariableServer;
yoVariableServer.setMainRegistry(registry, null);
TMotor hipMotor = new TMotor(RIGHT_HIP_CAN_ID, "hipMotor", TMotorVersion.AK109, DT, registry);
motors.put(hipMotor.getID(), hipMotor);
TMotorLowLevelController hipController = new TMotorLowLevelController("hipController", hipMotor, registry);
hipController.setUnsafeOutputSpeed(16.0);
motorControllers.put(hipMotor, hipController);
functionGenerator = new YoFunctionGenerator("functionGenerator", yoTime, registry);
functionGenerator.setAlphaForSmoothing(0.99);
TMotor kneeMotor = new TMotor(KNEE_CAN_ID, "kneeMotor", TMotorVersion.AK109, DT, registry);
motors.put(kneeMotor.getID(), kneeMotor);
TMotorLowLevelController kneeController = new TMotorLowLevelController("kneeController", kneeMotor, registry);
kneeController.setUnsafeOutputSpeed(16.0);
motorControllers.put(kneeMotor, kneeController);
motorIDs = motors.keys();
receivedMsg.setLength((byte) 6);
enableCANMsgs.set(true);
running.set(true);
private void initializeCAN()
if (!can.initializeAPI())
System.out.println("Unable to initialize the API");
System.exit(0);
else
System.out.println("CAN API has been initialized");
status = can.Initialize(channel, TPCANBaudrate.PCAN_BAUD_1M, TPCANType.PCAN_TYPE_NONE, 0, (short) 0);
@Override
public void run()
long controllerStartTime = System.nanoTime();
while (running.getBooleanValue())
effectiveDT.set(System.nanoTime() - tickStartTimeInNanos.getLongValue());
tickStartTimeInNanos.set(System.nanoTime());
yoTime.set(Conversions.nanosecondsToSeconds(tickStartTimeInNanos.getLongValue() - controllerStartTime));
if(resetCounters.getBooleanValue())
readErrorCounter.set(0);
writeErrorCounter.set(0);
resetCounters.set(false);
if (enableCANMsgs.getBooleanValue())
long canReadStartTime = System.nanoTime();
read();
canReadTime.set(System.nanoTime() - canReadStartTime);
long computeStartTime = System.nanoTime();
compute();
computeTime.set(System.nanoTime() - computeStartTime);
long canWriteStartTime = System.nanoTime();
write();
canWriteTime.set(System.nanoTime() - canWriteStartTime);
// TODO safe sentinel
// wait to free sent queue
yoVariableServer.update(tickStartTimeInNanos.getLongValue());
doControlTime.set(System.nanoTime() - tickStartTimeInNanos.getLongValue());
waitForNextPeriod();
private void read()
TPCANStatus readStatus = can.Read(channel, receivedMsg, null);
messagesInReadBus.set(0);
while(readStatus != PCAN_ERROR_QRCVEMPTY)
if (readStatus == TPCANStatus.PCAN_ERROR_OK)
int id = TMotorCANReplyMessage.getID(receivedMsg);
if(motors.containsKey(id))
motors.get(id).read(receivedMsg);
messagesInReadBus.increment();
else
readErrorCounter.increment();
private void compute()
for(int id = 0; id < motorIDs.length; id++)
motorControllers.get(motors.get(motorIDs[id])).setDesiredPosition(functionGenerator.getValue());
motorControllers.get(motors.get(motorIDs[id])).setDesiredVelocity(functionGenerator.getValueDot());
motorControllers.get(motors.get(motorIDs[id])).setDesiredTorque(0.0);
motorControllers.get(motors.get(motorIDs[id])).doControl();
private void write()
TPCANMsg motorCommand = motors.get(motorIDs[id]).getCommandedMsg();
status = can.Write(channel, motorCommand);
if (status != TPCANStatus.PCAN_ERROR_OK)
writeErrorCounter.increment();
public static void main(String[] args)
YoVariableServer yoVariableServer = new YoVariableServer(TMotorTestBed.class, null, new DataServerSettings(true), DT);
TMotorTestBed testbed = new TMotorTestBed(yoVariableServer);
yoVariableServer.start();
testbed.start();
testbed.join();
yoVariableServer.close();
