Retrieve Slave data from unconditional scheduler frames
davidd
Post by davidd » Wed 6. Apr 2022, 09:54
Hi!
I recently started developing a LIN-Master Script for communication with our LIN-Device.
I've attached a working test-script (please enable attaching .sh files in this forum).
Master Data is sent out on FrameID 32, Slave Data should be received on Frames 33-38.
I can confirm the functionality by attaching a logic-analyser: our device writes the Slave Data into the correct frames.
My problem is that I cannot retrieve this data from the scheduled frames.
I tried
./lin get sfe
to display the subscriber frames and also dumped all the memory transfered by ioctl - I only received 0's.
How do I implement this?
Thank you in advance!
- David
test-script.zip
(491 Bytes) Downloaded 2853 times
S.Grosjean
Re: Retrieve Slave data from unconditional scheduler frames
Post by S.Grosjean » Wed 6. Apr 2022, 14:55
To read data written by the slave, please use:
$ linread /dev/plin0
after having started the scheduler like you do. See also "linread --help" for a list of available options of the display format.
— Stéphane
