Linux & PCAN-USB: PCAN Interface Not Found
BetsyC
Post by BetsyC » Wed 6. Apr 2022, 14:56
I have PCAN- IPEH-002021 which has a stable, solid LED light. I have checked that the driver is installed to the latest version. In the Linux Terminal when I type
lsmod | grep ^peak
peak_usb        45056  0
When I am opening the program which uses the PCAN, it says PCAN Interface Not Found. Can you please tell me what am I missing?
I have already tried
grep PEAK_ /boot/config-`uname -r`
CONFIG_CAN_PEAK_PCMCIA=m
CONFIG_CAN_PEAK_PCI=m
CONFIG_CAN_PEAK_PCIEC=y
CONFIG_CAN_PEAK_USB=m
I have used the same PCAN device on the same laptop where it was working. So I am unsure what am I missing.
Re: PCAN- IPEH-002021 - PCAN Interface Not Found
Post by M.Maidhof » Thu 7. Apr 2022, 11:03
at the moment you are using the kernel included SocketCAN driver peak_usb and you can use it with the SocketCAN can-utils. Maybe your program runs only with the chardev driver interface, then you have to install the peak-linux-driver. Please see our Linux Website for more details.
