Dear Readers,
I own some PCAN USB adapters where I could easily develop and test software.
Now I want to use the same hardware to test an internal CAN Node.
But that fails because I can not find the node under "Intern" ( and the delivered sample software too ).
PCAN-Explorer 5 finds it.
How can I access the node under "Intern" to send and receive frames to it for test purposes?
Please see attachment.
If I need to pay a little, it would be OK for me.
Espen
Using PCAN Basic for internal Can network?
- pcan-internal.PNG (19.1 KiB) Viewed 2807 times
Re: Using PCAN Basic for internal Can network?
If you own a PE5 License, simply start the Net Configuration Tool, create a NET in the section "Intern" that fit to your need. Save the changes.
Now open PCAN-View and you will find the NET as a part of the Intern Tree.
Remark: please note that you cannot use PCAN-Basic with an internal net. You always need a physical channel to use the fee free API.
