Driver compatibility windows XP / windows 10
CAN Software API for Windows®. REGARD! This API is out-dated. Please use PCAN-Basic for new software developments.
biontresearch
Post by biontresearch » Mon 9. May 2022, 17:27
I use software that is written to run under windows XP, and communicates via a PEAK-CAN bus with a device.
Under windows XP the program works fine, but it doesn't under windows 10.
The software uses the PCAN light API v1.51.1.0. From viewtopic.php?f=40&t=1910 I understood that PCAN light should run fine under windows 10.
Is that also the case for v1.51 or should I replace this dll with a later version? It looks like PCAN light is no longer available from the Peak website. Is there an alternative source?
Re: Driver compatibility windows XP / windows 10
Post by PEAK-Support » Tue 10. May 2022, 08:04
Please use the latest Version of the PCAN-Light (link) and also the latest driver.All the needed files are still available on the WEB Page. See support section.
