CAN timing settings in C code
Hi. The C_POWER_STATES example code has the following CAN timing settings string: _80M_500K_80____4M_80_ISO. I think the 80M is the clock speed and the 500K is the nominal bit rate. What are the other settings in this string? Thanks!
Re: CAN timing settings in C code
please have a look in the can_user.h file for more details:
#ifndef _CAN_USER_H_
#define _CAN_USER_H_
// Each single value listed here will be a 'true' value. If hardware needs a '-1' decrement this is done by CAN_Initialize().
// clock arbitration phase misc CAN-FD data phase
// struct CANTiming_t = { can_clk, brp, tseg1, tseg2, sjw, limit, lo, mod, brp, tseg1, tseg2, sjw }
// max. values: 1024, 256, 128, 128, 255, 1, 2, 1024, 32, 16, 16
#define _80M___1M_80____4M_80_ISO { CAN_CLOCK_80M, 1, 63, 16, 1, 96, 0, 1, 1, 15, 4, 1} // 80 MHz, 1M 80%, 4M 80%, ISO
#define _80M_800K_80____4M_80_ISO { CAN_CLOCK_80M, 1, 79, 20, 1, 96, 0, 1, 1, 15, 4, 1} // 80 MHz, 800K 80%, 4M 80%, ISO
#define _80M_500K_80____4M_80_ISO { CAN_CLOCK_80M, 1, 127, 32, 1, 96, 0, 1, 1, 15, 4, 1} // 80 MHz, 500K 80%, 4M 80%, ISO
#define _80M_250K_80____2M_80_ISO { CAN_CLOCK_80M, 2, 127, 32, 1, 96, 0, 1, 2, 15, 4, 1} // 80 MHz, 250K 80%, 2M 80%, ISO
#define _80M_125K_80____2M_80_ISO { CAN_CLOCK_80M, 4, 127, 32, 1, 96, 0, 1, 4, 7, 2, 1} // 80 MHz, 125K 80%, 2M 80%, ISO
#define _80M_100K_80____1M_80_ISO { CAN_CLOCK_80M, 4, 159, 40, 1, 96, 0, 1, 4, 15, 4, 1} // 80 MHz, 100K 80%, 1M 80%, ISO
#define _80M__95K_80__500K_80_ISO { CAN_CLOCK_80M, 8, 83, 21, 1, 96, 0, 1, 8, 15, 4, 1} // 80 MHz, 95K238 80%, 500K 80%, ISO
#define _80M__83K_80__500K_80_ISO { CAN_CLOCK_80M, 16, 47, 12, 1, 96, 0, 1, 16, 7, 2, 1} // 80 MHz, 83K333 80%, 500K 80%, ISO
#define _80M__50K_80__500K_80_ISO { CAN_CLOCK_80M, 16, 79, 20, 1, 96, 0, 1, 16, 7, 2, 1} // 80 MHz, 50K 80%, 500K 80%, ISO
#define _80M__47K_80__500K_80_ISO { CAN_CLOCK_80M, 21, 63, 16, 1, 96, 0, 1, 16, 7, 2, 1} // 80 MHz, 47K619 80%, 500K 80%, ISO
#define _80M__33K_80__500K_80_ISO { CAN_CLOCK_80M, 24, 79, 20, 1, 96, 0, 1, 16, 7, 2, 1} // 80 MHz, 33K333 80%, 500K 80%, ISO
Perfect. Thanks!
