CANID Don't care filter
jafriede
Post by jafriede » Tue 16. Aug 2022, 19:01
It would be nice to have the option in "Symbol Properties" to set bits as a don't care for receive.
Re: CANID Don't care filter
Post by PEAK-Support » Wed 17. Aug 2022, 10:10
In which Tool or do you talk about the API / Driver ?
jafriede
Post by jafriede » Wed 17. Aug 2022, 16:15
I am using PCAN Explorer 6. Specifically in Tools->Symbol Editor
For example. In the screenshot below, it would be nice to mark certain bits in the CAN ID as "don't care"
PCAN Symbol.PNG (8.5 KiB) Viewed 11853 times
Post by PEAK-Support » Thu 18. Aug 2022, 08:02
Using the PCAN-Explorer, you could define own Filters inside the Project itself - not in the Symbol File.
Here you have many options.
Using a J1939 based network, where you definitally need to Mask the ID, there are special filter options like Prio, Source, Target, PGN.
The Filters also offer a "Exclude" Filter Option, to onvert the Filter.
jafriede
Post by jafriede » Thu 18. Aug 2022, 16:15
So apparently the J1939 module is required to set up a filter like this. We are not interested in J1939 although it is a proprietary J1939 style protocol. Is there a less expensive add-on for people who don't need to parse J1939 PGN's but need the filtering capability?
Post by PEAK-Support » Thu 18. Aug 2022, 16:29
The J1939 Protokoll Extension (Add-In) is need to setup J1939 Symbol Filters.
Also in the Symbol File you could use this Extension, and so save to use a Bit Filter:
