Tracer file playback from middle
SDOHFE
Post by SDOHFE » Fri 16. Sep 2022, 23:20
Is there a way to play a trace file from the middle?
Or
Is there a way to pause, back up 10 seconds, and play from there?
Re: Tracer file playback from middle
Post by PEAK-Support » Mon 19. Sep 2022, 08:21
The Tracer use the TRC Files. If you need only part of the files, simply use a Text Editor and Edit a copy of your original Trace in the way that it fit.
For example copy only the needed part from the Trace and paste it in a new Text File, copy the header and use the Trace file in the PCAN-Explorer.
We also offer a Tool to split larger Trace files in small single files ( link )
We also have build some sample PE6 Projects that allow you to read a Trace file line by line and add some "break points" and use the trace file with a single step feature.
If you send a e-mail to our support (including company name and license file number) we could send you the sample projects.
