peak-linux-driver-8.15.1 make problem on Debian 11
Fakier
Post by Fakier » Thu 22. Sep 2022, 11:51
I'm trying to install driver on a debian os
PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
NAME="Debian GNU/Linux"
VERSION_ID="11"
VERSION="11 (bullseye)"
VERSION_CODENAME=bullseye
ID=debian
HOME_URL="https://www.debian.org/"
SUPPORT_URL="https://www.debian.org/support"
BUG_REPORT_URL="https://bugs.debian.org/"
when set make command I get this error:
make[1]: Entering directory '/home/rock/peak-linux-driver-8.15.1/driver'
*** Host OS Release=Debian GNU/Linux v11
*** Host machine kernel version=4.4.194-4-rk3399-rockchip-g5fbf835e0ac4
*** Driver kernel version=4.4.194-4-rk3399-rockchip-g5fbf835e0ac4 (4.4.194)
*** Path to kernel sources=/usr/src/linux-headers-4.4.194-4-rk3399-rockchip-g5fbf835e0ac4
*** use KBUILD=yes
*** use DKMS=
*** gcc version=10
make -C /usr/src/linux-headers-4.4.194-4-rk3399-rockchip-g5fbf835e0ac4  EXTRA_CFLAGS="-I/home/rock/peak-linux-driver-8.15.1/driver -DNO_DEBUG -DMODVERSIONS -DNO_PARPORT_SUBSYSTEM -DUSB_SUPPORT -DPCI_SUPPORT -DPCIEC_SUPPORT -DISA_SUPPORT -DNO_DONGLE_SUPPORT -DNO_PCCARD_SUPPORT -DNO_NETDEV_SUPPORT -DNO_RT   -Wno-date-time" V=0 modules SUBDIRS=/home/rock/peak-linux-driver-8.15.1/driver
make[2]: Entering directory '/usr/src/linux-headers-4.4.194-4-rk3399-rockchip-g5fbf835e0ac4'
  CC [M]  /home/rock/peak-linux-driver-8.15.1/driver/src/pcan_main.o
/bin/sh: 1: ./scripts/recordmcount: Exec format error
make[3]: *** [scripts/Makefile.build:278: /home/rock/peak-linux-driver-8.15.1/driver/src/pcan_main.o] Error 126
make[3]: *** Deleting file '/home/rock/peak-linux-driver-8.15.1/driver/src/pcan_main.o'
make[2]: *** [Makefile:1479: _module_/home/rock/peak-linux-driver-8.15.1/driver] Error 2
make[2]: Leaving directory '/usr/src/linux-headers-4.4.194-4-rk3399-rockchip-g5fbf835e0ac4'
make[1]: *** [Makefile:523: all] Error 2
make[1]: Leaving directory '/home/rock/peak-linux-driver-8.15.1/driver'
make: *** [Makefile:84: all] Error 2
what could be the probblem?
S.Grosjean
Re: peak-linux-driver-8.15.1 make problem on Debian 11
Post by S.Grosjean » Thu 22. Sep 2022, 14:06
"scripts" is a Kernel directory, the place from where all the driver modules are built. I don't know which is the Kernel headers package you have installed but it looks like it doesn't suit your system architecture.
— Stéphane
Fakier
Post by Fakier » Thu 22. Sep 2022, 14:40
right now I'am trying to make the same on
NAME="Ubuntu"
VERSION="20.04 LTS (Focal Fossa)"
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME="Ubuntu 20.04 LTS"
VERSION_ID="20.04"
HOME_URL="https://www.ubuntu.com/"
SUPPORT_URL="https://help.ubuntu.com/"
BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
VERSION_CODENAME=focal
UBUNTU_CODENAME=focal
here is make result
*** Host OS Release=Ubuntu v20.04
*** use KBUILD=yes
*** use DKMS=
*** gcc version=9
/usr/bin/env: 'python': No such file or directory
In file included from /home/rock/peak-linux-driver-8.15.1/driver/src/pcan_common.h:39,
                 from /home/rock/peak-linux-driver-8.15.1/driver/src/pcan_main.c:36:
include/linux/kernel.h:5:10: fatal error: stdarg.h: No such file or directory
    5 | #include <stdarg.h>
compilation terminated.
any solution?
Fakier
Post by Fakier » Thu 22. Sep 2022, 14:55
I've included
/usr/include/c++/9
/usr/include/c++/9/tr1
and now it looks like
*** use KBUILD=yes
*** use DKMS=
*** gcc version=9
make -C /usr/src/linux-headers-4.4.194-4-rk3399-rockchip-g5fbf835e0ac4  EXTRA_CFLAGS="-I/usr/include/c++/9/tr1 -I/usr/include/c++/9 -I/home/rock/peak-linux-driver-8.15.1/driver -DNO_DEBUG -DMODVERSIONS -DNO_PARPORT_SUBSYSTEM -DUSB_SUPPORT -DPCI_SUPPORT -DPCIEC_SUPPORT -DISA_SUPPORT -DNO_DONGLE_SUPPORT -DNO_PCCARD_SUPPORT -DNO_NETDEV_SUPPORT -DNO_RT   -Wno-date-time" V=0 modules SUBDIRS=/home/rock/peak-linux-driver-8.15.1/driver
In file included from include/linux/kernel.h:6,
include/linux/linkage.h:7:10: fatal error: asm/linkage.h: No such file or directory
    7 | #include <asm/linkage.h>
I've checked that in
/usr/src/linux-headers-4.4.194-4-rk3399-rockchip-g5fbf835e0ac4/include
I have only
asm-generic
there is no
asm
generic,
is there any possibility to change makefile so it could compile on asm-generic?
S.Grosjean
Post by S.Grosjean » Thu 22. Sep 2022, 15:32
The errors you've got clearly show that your kernel-header package either is not correctly installed or does not correspond to your host machine.
Such an error in the Kernel means that your development suite is not correctly installed.
Do you really read the error messages?
/usr/include/c++/9
I confess that I do not understand what you say you have done here... More precisely, I am afraid to understand...
Building the driver normally is very easy, especially on Debian Linux machines, when one reads "Documentation/PCAN-Driver-Linux_UserMan_eng.pdf" first.
— Stéphane
Fakier
Post by Fakier » Fri 23. Sep 2022, 10:26
thank you for your answer,
right now post tittle is missleading, because right now I'm trying it on Ubuntu,
I'm trying it on a RockPI 4C+ device,
and I'm using a dedicated image
rockpi-4cplus-ubuntu-focal-server-arm64-20220901-0254-gpt.img
and it looks like it is not well prepared, because stdarg.h is missing in
directory.
Fakier
Post by Fakier » Fri 23. Sep 2022, 10:35
I have made a clean installation of rockpi-4cplus-ubuntu-focal-server-arm64-20220901-0254-gpt.img
and now I am getting error with recordmcount as it was in Debian
*** Driver kernel version=4.4.194 (4.4.194)
*** use KBUILD=yes
*** use DKMS=
*** gcc version=9
make[3]: *** [scripts/Makefile.build:278: /home/rock/peak-linux-driver-8.15.1/driver/src/pcan_main.o] Error 2
Is it because not correct linux-headers?
Fakier
Post by Fakier » Fri 23. Sep 2022, 14:01
to resolve this I've made
sudo -i
apt-get install libssl-dev build-essential -y
export HEADER_DIR=/usr/src/linux-headers-$(uname -r)
find "$HEADER_DIR/scripts" -type f | while read i; do if file -b $i | egrep -q "^ELF.*x86-64"; then rm "$i"; fi; done
cd $HEADER_DIR/scripts
gcc mkkrnlimg.c -o "$HEADER_DIR/scripts/mkkrnlimg"
gcc kallsyms.c -o "$HEADER_DIR/scripts/kallsyms"
gcc pnmtologo.c -o "$HEADER_DIR/scripts/pnmtologo"
gcc conmakehash.c -o "$HEADER_DIR/scripts/conmakehash"
gcc resource_tool.c -o "$HEADER_DIR/scripts/resource_tool"
gcc ./basic/bin2c.c -o "$HEADER_DIR/scripts/basic/bin2c"
gcc recordmcount.c -o "$HEADER_DIR/scripts/recordmcount"
gcc -I../tools/include sortextable.c -o "$HEADER_DIR/scripts/sortextable"
gcc unifdef.c -o "$HEADER_DIR/scripts/unifdef"
gcc ./basic/fixdep.c -o "$HEADER_DIR/scripts/basic/fixdep"
gcc extract-cert.c -o "$HEADER_DIR/scripts/extract-cert" -lssl -lcrypto
gcc ./mod/modpost.c ./mod/file2alias.c ./mod/sumversion.c -o "$HEADER_DIR/scripts/mod/modpost"
gcc ./mod/mk_elfconfig.c -o "$HEADER_DIR/scripts/mod/mk_elfconfig"
gcc  -I../include asn1_compiler.c -o "$HEADER_DIR/scripts/asn1_compiler"
ln -f ./genksyms/parse.tab.c_shipped ./genksyms/parse.tab.c;
ln  -f ./genksyms/parse.tab.h_shipped ./genksyms/parse.tab.h;
ln -f ./genksyms/lex.lex.c_shipped ./genksyms/lex.lex.c;
ln -f ./genksyms/keywords.hash.c_shipped ./genksyms/keywords.hash.c;
gcc ./genksyms/genksyms.c ./genksyms/parse.tab.c ./genksyms/lex.lex.c -o "$HEADER_DIR/scripts/genksyms/genksyms"
# Rebuild dkms Package (ex.)
sudo dpkg-reconfigure wireguard-dkms
deepakverma92
Post by deepakverma92 » Wed 16. Nov 2022, 18:28
Hi Fakier,
had the same problem. This helped. Could you tell what you are doing in those steps, just for understanding?
Thanks & regards,
Deepak
Post by PEAK-Support » Thu 24. Nov 2022, 09:26
Hi Fakier,
Thanks & regards,
Deepak
see code from Fakier...it is self explaining :)
