I need to send UDS Service with system supplier UDS Service ID 0xBE.
it is part of the UDS 14229 spec, under the user defined services
Is any way we can send request using PEAK PCAN-UDS 2.x API
PCAN-UDS_2013.h
PCAN-ISO-TP_2016.h
PCANBasic.h
Service request format : 10 13 BE 10 03 22 24 26
where 0x10 is the First Frame Indication, 0x13 is the size(number of bytes which will be next transmitted)
0XBE : UDS Service ID.
How to send such request using PEAK UDS API ?
UDS Service request Using 0xBE System Supplier
Re: UDS Service request Using 0xBE System Supplier
the UDS service 0xBE is not one of the standard UDS service requests, so there is no "UDS_Srv***_2013" function for it in the API, like SvcDiagnosticSessionControl_2013. In order to send such a request, you need to use the function UDS_Write_2013. You need to specify the data needed for the service within the uds_msg buffer.
This should be something like:
More Info about UDS_Write_2013 can be found in the documentation, chapter 3.7.78
uint8_t SERVICE_IDENTIFIER = 0xBE;
uint32_t DATA_SIZE = 0x13;
uint8_t request_data[DATA_SIZE];
cantp_handle channel= cantp_handle.PCANTP_HANDLE_USBBUS1;
uds_msgconfig request_config= new uds_msgconfig(); // Fill the request_config as needed
uds_msg msg_buffer = new uds_msg();
status = UDS_MsgAlloc_2013(msg_buffer, request_config, DATA_SIZE);
if (UDS_StatusIsOk_2013(status))
*out_msg_request->links.service_id = SERVICE_IDENTIFIER;
memcpy(&msg_buffer->links.param[0], request_data, DATA_SIZE);
status = UDS_Write_2013(channel, msg_buffer);
Admin: --> Topic moved from Hardware/PCAN-USB to Development Packages/PCAN-UDS <--
We are writing application in c++.
1) How to define msg_buffer in your example ? if so uds_msg msg_buffer = new uds_msg(); What is header file required for same?
When We define uds_msg *msg_buffer = NULL We are getting error code 9 PCAN_STATUS_PARAM_INVALID_VALUE in status
Thanks and Regards,
Shail Shah
status = UDS_MsgAlloc_2013(msg_buffer, *config, DATA_SIZE);
if (UDS_StatusIsOk_2013(status_cbme))
*msg_buffer->links.service_id = SERVICE_IDENTIFIER;
status_cbme = UDS_Write_2013(channel, msg_buffer);
Shail Shah
Reason: code formatting
- Software Development
You need to include "PCAN-UDS_2013.h". You can also find working samples in the PCAN-UDS package.
