"Eternal" bit rate detection - how to cancel?
Mobile diagnostic device for CAN and CAN FD buses with optional J1939 add-in
Gottfried
Post by Gottfried » Mon 19. Dec 2022, 17:49
during bit rate detection, I disconnected the PCAN-Diag FD from the CAN line. Now it stays in the bit rate detection perhaps since half an hour.
I tried to connect it again to the CAN bus, but BusMaster shows me only CAN bus errors (as did before... This is why I wanted to use PCAN-Diag FD), and PCAN-Diag doesn´t react yet...
The display seems to be frozen: e.g. when I unplug the power supply, I see anyway in the top line the "power plugged in" symbol.
Is there the possibility to reset the device e.g. via a factory reset button or something? It doesn´t react to any buttons I press so far...
Thank you in advance,
Gottfried Bruckmann
Robert Bosch GmbH
Fuel Cell Stack testing
Re: "Eternal" bit rate detection - how to cancel?
Post by PEAK-Support » Tue 20. Dec 2022, 13:43
Could you please give us more information. In the Settings - Detect CAN Bitrate - you could select what exact you like to detect (CAN 2.0, CAN-FD ISO, CAN-FD non-ISO)
Which Settings do you use? We need to reproduce the problem here in our office. Normally the Right Button (4* --> Exit ) could be used to Exit the Scan.
Everytime you press exit, a scan algorithm is stopped - see counter on screen.
Please also send us the Serial Number, and the Firmware Version if you know it (i know, if the Device do not work, you could not read it - but maybe you know it)
Post by PEAK-Support » Fri 23. Dec 2022, 09:57
is your problem solved ?
Gottfried
Post by Gottfried » Fri 29. Sep 2023, 11:35
Sorry for the late reply, I only read this message when posting a new question to the Peak form :(
At least, I don´t remember that it occurred again.
Best regards, Gottfried Bruckmann
Robert Bosch GmbH
alexvr6
Post by alexvr6 » Tue 25. Jun 2024, 06:49
Hallo,
ich hatte gestern das gleiche Problem. Bei suchen der Bitrate hat sich der PCAN-Diag aufgehangen und ließ sich nicht mehr bedienen. Ich musste warten bis der Akku leer war und das Gerät neu zu starten. Gibt es eine Tastenkombination um das Gerät zum Neustart zu zwingen? Gibt es andere Lösungsansätze?
Gruß A. Trinks
Screenshot 2024-06-25 083735.jpg (57.93 KiB) Viewed 12883 times
** Picture resized by Admin **
Post by PEAK-Support » Tue 25. Jun 2024, 09:48
Das Problem ist bekannt und es gibt bereits einen Fix dafür
Wir werden diese Version demnächst releasen - senden Sie uns bitte eine E-mail an support[at]peak-system.com, wir werden Ihnen die neue Firmware dann vorab bereitstellen.
Um ein PCAN-Diag auszuschalten das nicht mehr reagiert, müssen Sei nicht warten bis die Akkus kleer sind.
Betätigen Sie den Drehknopf (drücken) und halten diesen für >10 Sekunden, dann wird die Selbsthaltung hart über ein Relais ausgeschaltet und das Gerät ist Stromlos.
Es kann dann jederzeit wieder normal eingeschaltet werden.
