PCAN GPS
Programmable Sensor Module with CAN Connection
S Ganapathy Ram
PCAN GPS
Post by S Ganapathy Ram » Thu 29. Dec 2022, 06:15
The Signals i get default from the dbc file has only GPS latitudes and longtitudes in degrees and minutes only and there is no seperate for seconds available. so it is not suitable for finding the gps location. Can anyone please suggest solution for getting exact location
S Ganapathy Ram
Re: PCAN GPS
Post by S Ganapathy Ram » Thu 29. Dec 2022, 07:23
Currently iam getting in DMS (Degrees Minutes and Seconds) value and how to get it in DD (Decimal Degrees). or i need to get seperate channels for minutes and seconds. so that i can plot the exact location in the map
S Ganapathy Ram
Re: PCAN GPS
Post by S Ganapathy Ram » Thu 29. Dec 2022, 07:42
The folllowing is the measurement data in this the minutes and seconds are not given seperately
Re: PCAN GPS
Post by PEAK-Support » Fri 30. Dec 2022, 16:10
3 Post - but sorry - we do not understand your problem?
The used GPS unit is a UBlox - datasheet is available on the PCAN-GPS product page.
Here you find all needed information. But you need to spend some time to read the Data sheet.
We also move the Post to the correct section ... please check next time where you start a Post
