PCAN GPS
Posted: Thu 29. Dec 2022, 06:15
by S Ganapathy Ram
The Signals i get default from the dbc file has only GPS latitudes and longtitudes in degrees and minutes only and there is no seperate for seconds available. so it is not suitable for finding the gps location. Can anyone please suggest solution for getting exact location
Re: PCAN GPS
Posted: Thu 29. Dec 2022, 07:23
by S Ganapathy Ram
Currently iam getting in DMS (Degrees Minutes and Seconds) value and how to get it in DD (Decimal Degrees). or i need to get seperate channels for minutes and seconds. so that i can plot the exact location in the map
Re: PCAN GPS
Posted: Thu 29. Dec 2022, 07:42
by S Ganapathy Ram
- The folllowing is the measurement data in this the minutes and seconds are not given seperately
- Capture.PNG (16.74 KiB) Viewed 4462 times
Re: PCAN GPS
Posted: Fri 30. Dec 2022, 16:10
3 Post - but sorry - we do not understand your problem?
The used GPS unit is a UBlox - datasheet is available on the PCAN-GPS product page.
Here you find all needed information. But you need to spend some time to read the Data sheet.
We also move the Post to the correct section ... please check next time where you start a Post
