PCAN Virtual Usage
Murat.Ocakturk
PCAN Virtual Usage
Post by Murat.Ocakturk » Mon 30. Jan 2023, 11:09
I'm trying to use virtual CAN device, similar to Vector virtual CAN device. However, PCAN virtual device is not visible.
I have PCAN developer license.
My problems:
- PCAN virtual is visible as a "Network", not a "Device". Is this normal?
- I cannot select PCAN virtual device from PCAN Passthru configuration window.
Here some screenshots:
- The virtual networks are visible in PCAN-view. However, they are not a device.
- Virtual device is not visible in Passthru device list:
Thank you,
Murat
Re: PCAN Virtual Usage
Post by PEAK-Support » Mon 30. Jan 2023, 16:38
** move the post to the correct section - please always check where to post requests - Admon - **
The PassThru is based on the PCAN-Basic API and so no "pre defined Net" could be used. You always need a real Hardware.
