Does TLINClientParam.clpOnReceiveEventHandle really work?
Murat.Ocakturk
Post by Murat.Ocakturk » Thu 2. Feb 2023, 07:26
"TLINClientParam" enumeration has "clpOnReceiveEventHandle" for setting handle for the receive event.
However, It is not used in the samples inside PLinAPI. Also, it is not documented in the GetClientParam and SetClientParam functions. Supported client parameters are documented for GetClientParam and SetClientParam. "clpOnReceiveEventHandle" is not included.
So, my question: "clpOnReceiveEventHandle" really supported by SetClientParam function?
Murat
Re: Does TLINClientParam.clpOnReceiveEventHandle really work?
Post by K.Wagner » Thu 2. Feb 2023, 10:21
Hello Murat,
it seems as this parameter, clpOnReceiveEventHandle , as well as clpOnPluginEventHandle were forgotten to be included in the documentation of LIN_GetCleintParam and LIN_SetClientParam. I nevertheless can confirm, that these parameters are supported by both functions (and class methods).
The samples use the timer approach, so that the use of those parameter was not needed. Here is an example on how to set and get the parameter in C#:
PLinApi.SetClientParam
// Member variable definition
System.Threading.AutoResetEvent m_Event;
// Member variable initialization
m_Event = new System.Threading.AutoResetEvent(false);
// Configuring reception event
int buffer = m_Event.SafeWaitHandle.DangerousGetHandle().ToInt32();
if (Peak.Lin.PLinApi.SetClientParam(m_hClient, Peak.Lin.TLINClientParam.clpOnReceiveEventHandle, buffer) == Peak.Lin.TLINError.errOK)
    MessageBox.Show("Handle was Configured: " + buffer.ToString());
else
    MessageBox.Show("Error configuring event handle ");
PLinApi.GetClientParam
// Retrieving reception event
int buffer;
if (Peak.Lin.PLinApi.GetClientParam(m_hClient, Peak.Lin.TLINClientParam.clpOnReceiveEventHandle, out buffer, 4) == Peak.Lin.TLINError.errOK)
    MessageBox.Show("Configured handle: " + buffer.ToString());
else
    MessageBox.Show("Error retrieving event handle ");
You need to use a thread to wait for the event signalization, when a message is received
System.Threading.Thread m_Thread;
m_Thread = new System.Threading.Thread(DoRead);
m_Thread.IsBackground = true;
m_Thread.Start();
private void DoRead()
     while (true)
        if(m_Event.WaitOne(50))
            ReadMessages();
I hope this helps you. Thanks for bringing this to our attention.
Murat.Ocakturk
Post by Murat.Ocakturk » Thu 2. Feb 2023, 11:42
Thank you Keneth for quick and perfect response.
Post by K.Wagner » Thu 2. Feb 2023, 14:56
you are welcome. Closed.
