How to configure the PCAN-LIN as slave?
RS-232 to CAN/LIN Interface
BinHuang
Post by BinHuang » Fri 10. Feb 2023, 03:57
I want to develop new software with PCAN-LIN,I know how to configure the PCAN-LIN as master and can receive data form other device,but I don't know how to set it as slave.
I have read the document - 'PCAN-LIN Protocol Definitions' , but I don't understand the file.Can you give me some examples to show me how to set?
Thanks!
Re: How to configure the PCAN-LIN as slave?
Post by M.Maidhof » Fri 10. Feb 2023, 09:37
you have to set the LIN termination to slave, and setup the frame config for the LIN frames you want to use as LIN slave to publisher with the needed length and checksum type. See the info in the following post on how to change the publisher data by CAN or serial streams:
https://forum.peak-system.com/viewtopic.php?f=22&t=6457
