PCAN-view as part of PC tool
vladok
Post by vladok » Wed 8. Mar 2023, 15:32
We have PC tool which uses PORT CANopen library.
We want to read all messages on CAN port, to see all other communication.
We have to add PCAN-view code to our C# PC tool application.
How we can do this job?
Is PCAN- view source code available?
Re: PCAN-view as part of PC tool
Post by PEAK-Support » Wed 8. Mar 2023, 15:37
This is a commercial Forum of the company PEAK-System. If you have a own CAN Interface, build your own CAN Sniffer 8-)
The source code is not available for other CAN PC Hardware. It is only for our original PEAK-System CAN Interfaces.
vladok
Post by vladok » Thu 9. Mar 2023, 08:04
Sorry, my English is not good enough, and you understand me wrong
We not have hardware , we use your Hardware IPEH-002022 and PCAN-Wireless Gateway DR.
We buy it directly from you.
And our costumer use same your hardware.
We make only software.
We use PORT CANopen library on PC and STM32.
We make our PC tool which control or analyze system of one to 32 electronic.
In system is one Master electronic, all other is slave.
And Master read SDOdomain block data
If PC tool read same or other SDOdomain data are a lot of not correct block SDOdomain transfer
Now we make new system where SDOdomain block will be bigger and we don’t want to PC tool disturb communication between master and slave electronic
We want to PC tool only read some CAN open object, for SDOdomain block only listen and write block data to file.
We use PCAN-view to save all commnunicaton to trc file and later we analyte this messages.
Now we want that one PC tool communicate with system with PORT CANopen library and read, analyze and save all messages in same time.
Post by PEAK-Support » Fri 10. Mar 2023, 07:43
If you are looking for a CAN-Open Software Layer that works with our CAN-Interfaces, you need to talk to PORT if they do support our API.
If not you could use the CAN-Open Libs. from our partner company EmSA, they support all PEAK-System hardware with their CAN-Open Libs.
