PCAN-USB in Windows Subsystem for Linux WSL2, Ubuntu 20.04
eALduderino
Post by eALduderino » Thu 23. Mar 2023, 21:40
Hi there,
should the Linux default drivers run in WSL2 Ubuntu 20.04 with Microsoft's custom Linux Kernel?
WSL2-Linux-Kernel-linux-msft-wsl-5.15.90.1
Also, should the proprietary driver package be buildable and installable in WSL2? So far I managed to build and install the custom Kernel and connect USB devices to WSL2 but I didn't manage to get my PCAN-USB to work in WSL since I couldn't initialize the default driver and/or install the proprietary one. I'd appreciate it if anyone could share some knowledge or point me in the right direction to get it to work.
When I tried to build the driver package the following errors occurred. Thanks for your help.
eal@ealwsl2:~/drivers/peak-linux-driver-8.15.2$ make clean all
make[1]: Entering directory '/home/eal/drivers/peak-linux-driver-8.15.2/driver'
/bin/sh: 1: Syntax error: end of file unexpected
/bin/sh: 1: Syntax error: end of file unexpected (expecting "then")
/bin/sh: 1: [: missing ]
rm -f src/*o src/*~ src/.*cmd *o *ko *~ .*cmd  pcan.mod.c Module.symvers modules.order .cache.mk
make[1]: Leaving directory '/home/eal/drivers/peak-linux-driver-8.15.2/driver'
make[1]: Entering directory '/home/eal/drivers/peak-linux-driver-8.15.2/lib'
rm -f src/*~
rm -rf obj lib obj32 lib32
make[1]: Leaving directory '/home/eal/drivers/peak-linux-driver-8.15.2/lib'
make[1]: Entering directory '/home/eal/drivers/peak-linux-driver-8.15.2/test'
rm -f src/*~ src/*.o *~ receivetest transmitest bitratetest filtertest pcanfdtst pcan-settings receivetest_posix transmitest_posix
make[1]: Leaving directory '/home/eal/drivers/peak-linux-driver-8.15.2/test'
make[1]: Entering directory '/home/eal/drivers/peak-linux-driver-8.15.2/libpcanbasic'
*** Processing 'pcanbasic' directory...
make[2]: Entering directory '/home/eal/drivers/peak-linux-driver-8.15.2/libpcanbasic/pcanbasic'
*** Cleaning PCANBasic library...
rm -f src/*~ out/*.o out/*.gcno *~ *.so.* *.so lib/*~ lib/*.so.* lib/*.so lib32/*~ lib32/*.so.* lib32/*.so out32/*.o out32/*.gcno
make[2]: Leaving directory '/home/eal/drivers/peak-linux-driver-8.15.2/libpcanbasic/pcanbasic'
*** Processing 'pcaninfo' directory...
make[2]: Entering directory '/home/eal/drivers/peak-linux-driver-8.15.2/libpcanbasic/pcaninfo'
*** Cleaning pcaninfo...
rm -f src/*~ src/*.o ../pcanbasic/src/*~ ../pcanbasic/src/*.o *~ *.so.* *.so pcaninfo.1.3.1 pcaninfo
make[2]: Leaving directory '/home/eal/drivers/peak-linux-driver-8.15.2/libpcanbasic/pcaninfo'
*** Processing 'examples' directory...
make[2]: Entering directory '/home/eal/drivers/peak-linux-driver-8.15.2/libpcanbasic/examples'
*** Processing examples 'console' directory...
make[3]: Entering directory '/home/eal/drivers/peak-linux-driver-8.15.2/libpcanbasic/examples/console'
*** Processing 'C' directory (console examples)...
make[4]: Entering directory '/home/eal/drivers/peak-linux-driver-8.15.2/libpcanbasic/examples/console/c'
*** Cleaning PCANBasic C examples
rm -f src/*~ src/*.o *~ pcanwrite pcanread pcaneventread pcaneventwrite
make[4]: Leaving directory '/home/eal/drivers/peak-linux-driver-8.15.2/libpcanbasic/examples/console/c'
*** Processing 'NativeC++' directory (console examples)...
make[4]: Entering directory '/home/eal/drivers/peak-linux-driver-8.15.2/libpcanbasic/examples/console/NativeC++'
*** Cleaning PCANBasic C++ examples...
make[5]: Entering directory '/home/eal/drivers/peak-linux-driver-8.15.2/libpcanbasic/examples/console/NativeC++/01_LookUpChannel'
rm -f *.o *~ ../LookUpChannel
make[5]: Leaving directory '/home/eal/drivers/peak-linux-driver-8.15.2/libpcanbasic/examples/console/NativeC++/01_LookUpChannel'
make[5]: Entering directory '/home/eal/drivers/peak-linux-driver-8.15.2/libpcanbasic/examples/console/NativeC++/02_GetSetParameter'
rm -f *.o *~ ../GetSetParameter
make[5]: Leaving directory '/home/eal/drivers/peak-linux-driver-8.15.2/libpcanbasic/examples/console/NativeC++/02_GetSetParameter'
make[5]: Entering directory '/home/eal/drivers/peak-linux-driver-8.15.2/libpcanbasic/examples/console/NativeC++/03_ManualRead'
rm -f *.o *~ ../ManualRead
make[5]: Leaving directory '/home/eal/drivers/peak-linux-driver-8.15.2/libpcanbasic/examples/console/NativeC++/03_ManualRead'
make[5]: Entering directory '/home/eal/drivers/peak-linux-driver-8.15.2/libpcanbasic/examples/console/NativeC++/04_ManualWrite'
rm -f *.o *~ ../ManualWrite
make[5]: Leaving directory '/home/eal/drivers/peak-linux-driver-8.15.2/libpcanbasic/examples/console/NativeC++/04_ManualWrite'
make[5]: Entering directory '/home/eal/drivers/peak-linux-driver-8.15.2/libpcanbasic/examples/console/NativeC++/05_TimerRead'
rm -f *.o *~ ../TimerRead
make[5]: Leaving directory '/home/eal/drivers/peak-linux-driver-8.15.2/libpcanbasic/examples/console/NativeC++/05_TimerRead'
make[5]: Entering directory '/home/eal/drivers/peak-linux-driver-8.15.2/libpcanbasic/examples/console/NativeC++/06_TimerWrite'
rm -f *.o *~ ../TimerWrite
make[5]: Leaving directory '/home/eal/drivers/peak-linux-driver-8.15.2/libpcanbasic/examples/console/NativeC++/06_TimerWrite'
make[5]: Entering directory '/home/eal/drivers/peak-linux-driver-8.15.2/libpcanbasic/examples/console/NativeC++/07_ThreadRead'
rm -f *.o *~ ../ThreadRead
make[5]: Leaving directory '/home/eal/drivers/peak-linux-driver-8.15.2/libpcanbasic/examples/console/NativeC++/07_ThreadRead'
make[5]: Entering directory '/home/eal/drivers/peak-linux-driver-8.15.2/libpcanbasic/examples/console/NativeC++/08_EventDrivenRead'
rm -f *.o *~ ../EventDrivenRead
make[5]: Leaving directory '/home/eal/drivers/peak-linux-driver-8.15.2/libpcanbasic/examples/console/NativeC++/08_EventDrivenRead'
make[5]: Entering directory '/home/eal/drivers/peak-linux-driver-8.15.2/libpcanbasic/examples/console/NativeC++/09_TraceFiles'
rm -f *.o *~ ../TraceFiles
make[5]: Leaving directory '/home/eal/drivers/peak-linux-driver-8.15.2/libpcanbasic/examples/console/NativeC++/09_TraceFiles'
make[4]: Leaving directory '/home/eal/drivers/peak-linux-driver-8.15.2/libpcanbasic/examples/console/NativeC++'
make[3]: Leaving directory '/home/eal/drivers/peak-linux-driver-8.15.2/libpcanbasic/examples/console'
*** Processing examples 'gui' directory...
make[3]: Entering directory '/home/eal/drivers/peak-linux-driver-8.15.2/libpcanbasic/examples/gui'
*** Processing 'python' directory (GUI examples)...
make[4]: Entering directory '/home/eal/drivers/peak-linux-driver-8.15.2/libpcanbasic/examples/gui/python'
rm -f *.pyc
make[4]: Leaving directory '/home/eal/drivers/peak-linux-driver-8.15.2/libpcanbasic/examples/gui/python'
make[3]: Leaving directory '/home/eal/drivers/peak-linux-driver-8.15.2/libpcanbasic/examples/gui'
make[2]: Leaving directory '/home/eal/drivers/peak-linux-driver-8.15.2/libpcanbasic/examples'
make[1]: Leaving directory '/home/eal/drivers/peak-linux-driver-8.15.2/libpcanbasic'
*** Host OS Release=Ubuntu v20.04
*** Host machine kernel version=5.15.90.1-microsoft-standard-WSL2
*** Driver kernel version=5.15.90.1-microsoft-standard-WSL2 (5.15.90)
/bin/sh: 1: Syntax error: Unterminated quoted string
make[1]: *** [Makefile:774: message] Error 2
make: *** [Makefile:84: all] Error 2
Re: PCAN-USB in Windows Subsystem for Linux WSL2, Ubuntu 20.04
Post by G.Lang » Fri 24. Mar 2023, 07:23
Windows Subsystem for Linux (WSL) is not a real fully working Linux system (it´s a virtualized Linux with special kernel) and therefore the PCAN-USB will not work. Please install a real Linux distribution and then the PCAN-USB will properly work.
eALduderino
Post by eALduderino » Fri 24. Mar 2023, 10:11
I was afraid this is the case. Thanks for your quick reply.
tim.rosenkrantz
Post by tim.rosenkrantz » Wed 16. Aug 2023, 07:15
The driver might not work but you can still use PCAN-USB with the built in kernel support via socketcan
I am using WSL2 (win10 , 22H2, 19045.3208) with a custom built kernel based on 5.15.90.1 where I have added CAN and USB support.
Then using usbipd to forward the usb to WSL2 hxxps://github.com/dorssel/usbipd-win
I configure the can0 interface with systemd and load can and can_raw modules at boot
/etc/systemd/network/80-can.network
[Match]
Name=can0
[CAN]
BitRate=500000
SamplePoint=80%
FDNonISO=False
DataBitRate=2000000
DataSamplePoint=80%
FDMode=True
/etc/modules-load.d/can.conf
can
can_raw
gsibley
Post by gsibley » Wed 6. Dec 2023, 02:08
Hi all,
Tim's suggestion seems to be a workable path to use PCAN-USB FD device under wsl, but I still don't see can0 showing up.
I setup usbipd, systemd and /etc/modules-load.d/can.conf as suggested. In wsl dmesg shows the driver being loaded when I activate the device from windows (with "usbipd wsl attach --busid=8-1"):
[ 6517.793791] vhci_hcd vhci_hcd.0: pdev(0) rhport(0) sockfd(3)
[ 6517.793825] vhci_hcd vhci_hcd.0: devid(524289) speed(3) speed_str(high-speed)
[ 6517.793851] vhci_hcd vhci_hcd.0: Device attached
[ 6518.160335] usb 1-1: new high-speed USB device number 3 using vhci_hcd
[ 6518.310224] usb 1-1: SetAddress Request (3) to port 0
[ 6518.343093] usb 1-1: New USB device found, idVendor=0c72, idProduct=0012, bcdDevice= 0.00
[ 6518.343122] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6518.343124] usb 1-1: Product: PCAN-USB FD
[ 6518.343125] usb 1-1: Manufacturer: PEAK-System Technik GmbH
However this does not activate can0 and "ip -s -d link show type can" comes up blank. I was previously only able to get the can0 to show up if I compiled the pcan drivers with "netdev" option, and for now I'm using the driver from the kernel (make menuconfig etc). What step am I missing to get can0 to show up? Many thanks for your help.
Post by G.Lang » Wed 6. Dec 2023, 09:43
maybe you don´t have uninstalled our PCAN driver correctly. Please go to the PCAN driver directory and type "sudo make uninstall" and reboot the linux system afterwards, then the normal kernel-integrated SocketCAN driver should be present. After the system was rebooted please check if the CAN driver is part of your Linux and also if the device is initialized.
Please note that WSL2 don´t support USB officially. To make USB work with the help of the "usbipd-win " project is not really supportable from PEAK.
Such a system may work or may not.
gsibley
Post by gsibley » Thu 7. Dec 2023, 00:18
Hi All,
I was able to get it working by compiling the 6.1 kernel from MS github. Roughly following the instructions here: hxxxs://learn.microsoft.com/en-us/community/content/wsl-user-msft-kernel-v6 and here: xxx.reddit.com/r/CarHacking/comments/ot3gjf/socketcancanutils_on_windows/.
I did this because Check #3 here xxx.peak-system.com/fileadmin/media/linux/index.htm indicated the device was only supported with Linux >= 6.0. (Check #1 and #2 passed)
Thanks!
(active links are Not allowed - see forum RULES - changed by Admin)
