Instrument Panel select Signal of node with range
bkiepke
Post by bkiepke » Wed 31. May 2023, 10:41
If a symbol is defined in a symbol file as follows:
[Vert_X28_NMT_HEARTBEAT]
ID=750h-751h
DLC=1
Var=s NMTState 0,7
Var=reserved unsigned 7,1
so it does contain a range as ID, how can a signal of a specific node be selected within a intrument panel?
Re: Instrument Panel select Signal of node with range
Post by PEAK-Support » Wed 31. May 2023, 12:01
If you define a Symbol like this
ID=750h-751h
DLC=1
Var=s NMTState 0,7
The Signal "s" is always the same ! If you reciece ID0x750 with valid Data, the signal "s" is set, if your receive ID0x751with valid Data the signal "s" will also be set.
See Symbol Documentation inside the PE6 Online Help.
// The following symbol matches all received messages that have a
// CAN ID in the range 300h to 400h and length 5
[RcvSymbol]
ID=300h-400h
Len=5
Sig=BitfieldValue 0
Sig=MotorolaValue 16
Sig=EnumValue     32
If you want seperateted Signals, you need to define seperated Symbols.
[Vert_X28_NMT_HEARTBEAT_1]
ID=750h
DLC=1
Var=s NMTState 0,7
[Vert_X28_NMT_HEARTBEAT_2]
ID=751h
DLC=1
Var=s NMTState 0,7
