PCAN-USB: Received messages are acknowlegded but not displayed by PCAN-View
Posted: Mon 19. Jun 2023, 20:11
I am trying to view CAN2.0 messages sent from an embedded MCU on PCAN-view. I have a scope connected to the bus decoding CAN frames as well. I have verified that my embedded device can receive messages from PCAN-View, and I have verified that electrically everything is in order (bus levels, time bases).
As part of my testing I have sent a simple message FROM the PCAN-view terminal to the embedded HW and recorded the waveform. Its acked by the embedded HW and i can see it in embedded memory. Thats all good.
I then send the same message (same ID, DLC, payload...) back from the embedded device to PCAN-view. On the scope i can see that the waveform is identical, so I know i'm sending exactly the same message with the same timing. I also see PCAN-view ACK the message. However nothing appears in the Receive/Transmit window.
I have the acceptance filter set to accept everything. I have both embedded and PCAN setup for 125kbs with 80% sample points. How is it possible that PCAN-view acks a message (indicating to me the message validity) but doesnt display anything? Any help/pointers are hugely apprecaited.
Im running PCAN-view 5.0.5.871
I have PCAN-USB HW with firmware 8.3.0 and driver 4.4.0
Screen captures:
Figure 1 shows PCAN sending message (yellow) and embedded acking (blue)
Figure 2 shows embedded sending message (blue) and PCAN acking (yellow)
-Alexander
Screen captures:
-Alexander
