PCAN-View: Is it possible to use PCAN-View for basic tasks in CANopen?
Mogaraghu
Post by Mogaraghu » Wed 16. Aug 2023, 16:24
Just with PeakCAN View + USB Adaptor is it possible to send CANopen messages and check out basic functionality of some CANopen sensors ?
Re: PEAK CAN View and CANOpen
Post by PEAK-Support » Wed 16. Aug 2023, 16:29
Yes, as CANopen is only a Software Layer on CAN-Layer 2, you could use the PCAN-View to send / receive CANopen Data if you know how to do.
But a CANopen Software Tool makes it more easy. See CANopen Magic from our partner EmSA.
Other Tools taht could be used with our PEAK-System CAN Interfaces are also available - see here
Mogaraghu
Post by Mogaraghu » Thu 17. Aug 2023, 08:33
Thanks for responding and giving a full list of CANopen software links. I will go through the same patiently. In the meanwhile I just want to query the CANopen Encoder that I have for the Resolution value stored at
SDO COB ID : 0x662
Command : 0x22
Index : 6502
Sub Index : 00
How to enter this in the Transmit Dialog box ?
Screenshot 2023-08-17 120148.png (41.06 KiB) Viewed 27386 times
Post by PEAK-Support » Thu 17. Aug 2023, 08:48
That is exact the reason why you need to use CANopen Tools if you are not common with the CANopen Protocols.
If you do not want to use any recommended CANopen Tools, you need to read and fully understand the CANopen Specification - a simply answer could not be given.
so we close this Topic
