I'm currently using three PCAN-USB devices connected to a PCAN-Router Pro. I'm working on reading and writing data using Python with the PCANBasic.py API.
However, I'm encountering an issue. When I attempt to send a message with my second PCAN-USB device, it also sends the same message via the first PCAN-USB device. I'm unable to separate between these two PCAN-USB devices. When I send a message exclusively to my first PCAN-USB, it works as expected. However, when I send it to the second PCAN-USB, it sends the message with both devices.
I have already configured each PCAN-USB device with a unique ID and added them to my registry editor.
Has anyone experienced a similar issue and found a solution?
Thank you!
Emre
PCAN-USB Message Duplication Problem
Re: PCAN-USB Message Duplication Problem
please provide some more details about used driver/firmware/PCANBasic version. As a test please use two instances of the PCANBasic demo application which you find in the PCANbasic package and test if you have the same behaviour with that application when using two different PCAN-USB modules.
for both devices in the properties of PEAK Hardware it says 8.6. I can show a short code snippet which I'm currently using if that helps:
pcan = PCANBasic()
pcan.Initialize(PCAN_USBBUS1, PCAN_BAUD_500K)
pcan.Initialize(PCAN_USBBUS2, PCAN_BAUD_500K)
while True:
msg_1 = createPCANMessage(0x1, 6, (0x01, 0x00, 0x00, 0x00, 0x00))
print(f"msg 1: {msg_1}")
pcan.Write(PCAN_USBBUS1, msg_1)
msg_2 = createPCANMessage(0x2, 8, (0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00))
print(f"msg 2: {msg_2}")
pcan.Write(PCAN_USBBUS2, msg_2)
time.sleep(0.1)
how about the tests with the test applications and driver and API version?
