I have a dbc file, and I'd like to design a simple Panel (leds , gauges, etc) in PCAN-Explorer , that can decode real-time can-bus traffic as well as playback previously captured .trc files. Is this functionality included in the base PCAN-Explorer product?
I couldn't find anything in the documentation that describes the above. For example, the tutorial video "Tracer 1: Recording and Playback" does not show playback of a trc file in a panel designed in PCAN-Explorer .
Is the Plotter add-on needed? If not, does the Plotter just a new "Instrument" for the Panel? i.e. You can drag a Plotter widget into the panel, assign it to a signal, so that the signal is shown on a graph?
Is Plotter Add-in needed for trc playback within Explorer?
Re: Is Plotter Add-in needed for trc playback within Explorer?
The Plotter AddIn is completely independent from the User Panel - see product description.
Playback of loaded Trace file also have nothing to do with Plotter / User Panel . It is part of the main Product.
You could remotely control the Tracer via script, and so also could do this from the user panel (execute command).
For more, detailed, answer, please contact our product support. As the PE6 is a commercial Software, we need to check the licensee and company information up in front.
